After enabling MCUBoot in NCS, external flash doesn't get picked up by littleFS
Hello:
I am using an nrf52840 on a custom board with W25Q01NV NOR Flash with the Nordic QSPI-NOR driver. Programming is with NCS v 1.8.0 (upgraded yesterday) and the VS Code extension.  I am using the external Flash partition only for storage of data collected by the device and not for use with MCUBoot or for anything else. This setup was previously working with nrf5 SDK and recently moved to NCS.
When the CONFIG_BOOTLOADER_MCUBOOT option is not enabled, the code works fine, mounts the parittion and starts recording the data, but when I enable MCUBoot, LittleFS mounts on an internal flash parition. I found this related issue here: https://devzone.nordicsemi.com/f/nordic-q-a/62212/external-spi-flash-to-use-with-littlefs-on-nrf9160-w-mcuboot, but that was from a year ago and there was no resolution to that issue.
Again, I do not want to store MCUBoot images on the external flash, but I want to still use it for storage and I need MCUBoot enabled for upgrades as usual with the internal flash only.
Any help is appreciated.
Ashwin
  • I have now added these to the pm_static.yml
    external_flash:
    address: 0x120000
    placement:
    after:
    - mcuboot_secondary
    device: W25Q01JV
    region: external_flash
    littlefs_storage:
    address: 0x00000
    device: W25Q01JV
    And now the littlefs_storage doesn't seem to be located in primary flash:
      flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0xc000 - 48kB)                    |
    +---0xc000: mcuboot_primary (0x7a000 - 488kB)-----+
    | 0xc000: mcuboot_pad (0x200 - 512B)              |
    +---0xc200: mcuboot_primary_app (0x79e00 - 487kB)-+
    | 0xc200: app (0x79e00 - 487kB)                   |
    | 0x86000: mcuboot_secondary (0x7a000 - 488kB)    |
      sram_primary (0x40000 - 256kB):
    | 0x20000000: sram_primary (0x40000 - 256kB) |
    But when the code starts, it still seems to pickup from the same NRV_FLASH_DRV_NAME paritition.
    *** Booting Zephyr OS build v2.7.0-ncs1 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0xc000
    I: Jumping to the first image slot [00:00:00.143,432] [0m<inf> littlefs: littlefs partition at /lfs1[0m
    [00:00:00.143,676] [0m<inf> sdc_hci_driver: SoftDevice Controller build revision:
    df c0 4e d6 1f 7c 66 09 0a f5 2b a0 98 f2 43 64 |..N..|f. ..+...Cd
    62 c5 a6 2a |b..* [0m
    Bluetooth initialized
    Advertising successfully started
    Found device MAX17262
    Found device LSM6DSL
    Found device TPS65721
    Found device MAX30003
    Starting in PatchPro ModeSend Data Thrd STRT
    Mounting Disk...
    Area 0 at 0x0 on NRF_FLASH_DRV_NAME for 49152 bytes
    [00:00:00.649,719] [0m<inf> littlefs: LittleFS version 2.2, disk version 2.0[0m
    [00:00:00.649,780] [0m<inf> littlefs: FS at NRF_FLASH_DRV_NAME:0x0 is 12 0x1000-byte blocks with 512 cycle[0m
    [00:00:00.649,780] [0m<inf> littlefs: sizes: rd 32 ; pr 32 ; ca 64 ; la 32[0m
    [00:00:00.649,871] [1;31m<err> littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:997: Corrupted dir pair at {0x0, 0x1}[0m
    [00:00:00.649,871] [1;33m<wrn> littlefs: can't mount (LFS -84); formatting[0m
    [00:00:00.680,755] [1;31m<err> os: ***** BUS FAULT *****[0m
    It looks to me like that this is picked up from some other place.
  • I don't have W25Q01NV NOR Flash. But I was able to get this to work using the nRF52840 DK an it's integrated external flash.
    In the sample below, the littlefs storage is placed inside the external flash, and the secondary slot is placed in the primary slot
    2654.littlefs_ext_flash_sec_slot_in_internal.zip
    If it works successfully, you should get the following output:
    I: Swap type: none
    Area 1 at 0x0 on MX25R64 for 24576 bytes
    /lfs mount: 0
    [/lfs: bsize = 16 ; frsize = 4096 ; blocks = 6 ; bfree = 4
    00/lfs/boot_count stat: 0
            fn 'boot_count' size 4
    :00/lfs/boot_count read count 2: 4
    /lfs/boot_count seek start: 0
    /lfs/boot_count write new boot count 3: 4
    :00/lfs/boot_count close: 0
    .00/lfs opendir: 0
      F 4 boot_count
    End of files
    /lfs unmount: 0
    7,843] <inf> littlefs: LittleFS version 2.2, disk version 2.0
    [00:00:00.007,873] <inf> littlefs: FS at MX25R64:0x0 is 6 0x1000-byte blocks with 512 cycle
    [00:00:00.007,873] <inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32
    [00:00:00.009,826] <inf> littlefs: /lfs mounted
    [00:00:00.043,334] <inf> littlefs: /lfs unmounted
    This is the result after running ninja partition_manager_report:
      external_flash (0x800000 - 8192kB):
    | 0x0: external_flash (0x800000 - 8192kB) |
    | 0x0: littlefs_storage (0x6000 - 24kB)   |
    Could you test this first with the nRF52840 DK, and if that runs successfully, modify it it to work with the W25Q01JV.
    Simon
  • Thank you Simon for posting the sample project.
    I can confirm that this indeed works with the nrf DK board.
    Also, on my board, the partition structure is showing fine.
      external_flash (0x8000000 - 131072kB):
    | 0x0: external_flash (0x8000000 - 131072kB)   |
    | 0x0: littlefs_storage (0x8000000 - 131072kB) |
    The following were the essential things I changed (compared to my previous configuration to make this work):
    1. Define partitions only in the pm_static.yml file (earlier I was declaring everything, including littlefs config in an overlay file using an fstab entry). In my code now, I define the FS entry inline itself.
    2. Added this to my overlay :
    chosen {
    nordic,pm-ext-flash = &w25q01jv;
    3. Include the option CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n in my prj.conf file
    I am getting a different error now saying that it cannot find the flash device, but I guess that must be a different issue. I will check and raise another ticket if necessary, but here is my output after this:
    I: Swap type: none
    [00:00:00.143,768] <inf> sdc_hci_driver: SoftDevice Controller build revision:
                                             62 c5 a6 2a                                      |b..*
    Mounting Disk...
    Area 1 at 0x0 on W25Q01JV for 134217728 bytes
    [00:00:00.950,225] <inf> littlefs: LittleFS version 2.2, disk version 2.0
    [00:00:00.950,256] <err> littlefs: can't get flash device: W25Q01JV
    [00:00:00.950,256] <err> fs: fs mount error (-19)
    FAIL: mount id 1 at /lfs1: -19
    Load IDX...
    [00:00:01.950,500] <err> fs: mount point not found!!
    FAIL: open /lfs1/index: -2
