Device name has only 4 letters
Hello everyone,
I have a problem with my device name. First of all I want tro write the device ID into the device name. I get the device ID over "RF_FICR->DEVICEID[0]".
That means I want to write the device name into a int or char and not with a #define as it is right now. Additionaly I tried to only modify the device name over #define and it shows me only the first 4 letters. I checked everything and I cannot find the problem.
I checked:
init.advdata.name_type               = BLE_ADVDATA_FULL_NAME
#define BLE_GAP_DEVNAME_MAX_LEN                  248
I dont understand why it advertises only 4 letters. I tried to make the implementation like following:
char device_namee[8] ="EF234ABC";
const uint8_t * p_device_name =&device_namee[8];
    ret_code_t              err_code;
                                          p_device_name,
                                          strlen(device_namee));
    gap_conn_params = m_scan.conn_params;
If I adveritse like that it shows me nothing or difficult symbols...
Summerized:
  • If I use the method with #define I am only able to write 4 letter
  • If I try to write my own name over char and not over #define it doesnt show anything only some difficult symbols
Best regards!
  • Hi Hani
    I noticed that you declare device_namee like this: char device_namee[8] ="EF234ABC".
    So basically you are declaring an array with 8 bytes of type char.
    Then you set a pointer to this array, as follows: const uint8_t * p_device_name =&device_namee[8]
    I believe that you should declare the pointer like this: const char * p_device_name =&device_namee   (no array size identifier here!)
    That's my two cents. Let me know how that goes.
    Cheers
    Rob
  • This:
    Is getting the address of the 8th character in `device_name`, so the p_device_name pointer is pointing to the memory after the string.
    You can either change to
    char device_namee[9] ="EF234ABC";
    const uint8_t * p_device_name = device_namee;
    (needs to be 9 to accommodate for the null terminator byte)
    Or just not bother with the other variable and go with
    static const char* device_name ="EF234ABC";
                                              device_name,
                                              strlen(device_name));
