Is it possible to update SDK without updating softdevice version?
Hi Team,
Currently in our project we use nrf52840 SDK15.2.0 and softdevice s140_nrf52_6.1.1_softdevice
Now we would like to update the SDK to 17.1.0 without updating the softdevice
is this possible? can we update the SDK alone ?
    Generally, SoftDevice with different major version numbers have API changes. And the SDK are only adapted to use the SoftDevices they ship with. That means that you will need to make some adjustments in the SDK code, and you will need to properly test this. There has not been a whole lot of changes during the last few SoftDevice released though, so you should not need a lot of effort to port SDK 17.1.0 to a 6.1.1 SoftDevice.
    I wonder why you want to keep the old SoftDevice though, can you elaborate on that? Why not just migrate to a updated SoftDevice as well?
    Thanks for the info.
    since many of our users doesn't have the tool to update softdevice , we thought to update only sdk.
    i tried porting the SDK alone, after porting the examples are compiling fine but i see the below issue
    ble examples are working fine in Web Device CLI (makerdiary.com) and Serial Bluetooth Terminal
    but in nrf connect app data transmission is not happening as expected it stops after few bytes
    do you have any idea why this is happening?
  • I don't have any ideas from the top of my head, no. So you need to debug in order to see what is happening.
    Before that, please ensure that the basics is in place: You are using the header files for the SoftDevice you are actually using. Also, as there are API changes you will need to handle those. To see if you forgot some I recommend you read the SoftDevice migration document, which is quite detailed and describes all changes you need to take care of (in this case you would red it the other way, as you are migrating SDK 17.1.0 to an older SoftDevice, so start with the migration document for S140 7.2.0 and see all changes from 6.1.1, and ensure that you handle those. There are not many changes, though.
  • I see that the data structures used by the Soft Device handlers (i.e. nrf_sdh_*?) in SoftDevice 7.2 (which is the norm in SDK 17.1.0) add at least one extra field when compared to their counterparts in SoftDevice 6.1.1 (which is the default in SDK 15.x.y).
    This tells me that you cannot mix and merge boot loaders (which you cannot update in your case) and applications to use different Soft Device versions.
    Hope this helps you make a better choice.
