Low output power on DevBoards
Hi
I measured the CW output power of several DevBoards (nRF52832 and nRF52840) and the output power is much lower than expected.
Setup:
  • nRF52832 or nRF52840 DevBoard connected to spectrum analyzer using Murata RF Probe (see image below)
  • Nordic DTM firmware running in Tx mode, output power = 0dBm, pattern = "vendor specific", packet length: 1 byte, channel: 19
  • Measured power on spectrum analyzer is as low as -3dBm (cable loss already calibrated out)
Question:
Why is the measured power so low? I would have expected something in the range of 0..-1dBm. The spectrum analyzer was recently calibrated and I verified the measurement with 4 different boards with equal results. If I set the output power of the chips to +4dBm, the measured power increases by 4dB as expected.
For me there are three options:
  1. The chips are not working properly
  2. The ANT pin is not properly matched to 50 ohms
  3. The Murata socket / probe combination lead to high loss
Thanks for your help & best regards
Rashid
