ble_app_uart can not start advertising
Hi everyone,
I implement nrf5_SDK_17.0.2 ble_app_uart example, but when I connect both GND wire and TX wire of the external device to my nRF52840 DK first, my nRF52840 DK cannot start advertising even the external device is off. So I have to turn my nRF52840 DK on first, and then I connect the external device.
The most important problem is that when I press the reset button on my nRF52840 DK I need to reconnect the common GND or TX wire, otherwise my nRF52840 DK cannot start advertising.
Note: the external device's logic level is +5V so I have to use a lever shifter.
Thanks.
  • Likely the Rx pin doesn't have PULLUP enabled and so floats about as it picks up random electrical noise, generates a framing error which maybe stops BLE working. Test by enabling PULLUP on the Rx pin after doing the init() of the serial port. Another fix is to add an external pull-up resistor between Rx pin and VCC (say100k but any value will probably work). The internal PULLUP resistor is about 14k, which won't affect the FTDI when you do connect the FTDI
  • Hi hmolesworth
    Thank you from your reply.
    I add an external pull-up resistor, which is 2K Ohm between Rx pin and +3V. So when the external device is off my nRF52840 DK can start advertising.
    But, after turning the external device on if I press the reset button on my nRF52840 DK advertising cannot be started.
    What do you suggest?
  • I suggest to try a fail a bit, for instance look at a logic analyzer trace, does something look off? Maybe try with pull-ups on both RX and TX, and the pull up's can be large >100kohm. Look at the timing when working vs. failing, and also it should be possible to debug your program (e.g. in DEBUG build) to check for faults, asserts, or if the program just hang (e.g. wait) somewhere.
    Kenneth
  • Hi Kenneth,
    I try to measure RX Pin in some cases:
    1- Before connecting the external device to my nRF DK, RX Pin voltage is +2.74V.
    2- After connecting the external device to my nRF DK:
    • When the external device is off RX Pin voltage is +0.72V. In this case the nRF DK cannot start advertising.
    • If you add a 2kOhm pull-up resister RX pin voltage is +1.45V. In this case the nRF DK can start advertising.
    • When the external device is on, at the beginning RX Pin voltage is +3.45V. After a few minutes RX Pin voltage is +2.88V ~ +2.93V. In this case the nRF DK cannot start advertising.
    • Now, if you first disconnect the common ground and then connect your app to the nRF DK you can see the data in your app after connecting the common ground later. In this case RX Pin voltage is +2.90V ~ +2.95V.
    Note: You shouldn't add a pull-down resister because by doing that, advertising cannot be started at all even if you disconnect the common ground. I added a 4kOhm pull-down resister and saw that RX Pin voltage has been +1.42 ~ +1.45. And also I added a 14kOhm pull-down resister and saw that RX Pin voltage has been +2.76 ~ +2.81V. But, it stopped advertising.
    Could you guess what the problem is?
    Thank you for your answer.
  • The GPIO voltages should not at any time exceed 0.3V above/below power supply rails, doing to may damage the device over time (since the ESD protection diodes on the GPIO pads will sink or source current when this occurs, they are designed to handle short ESD transients only).
    I am not sure what you mean by device if off? If you mean there is no voltage applied to the device, then I assume the device will try to sink current through GPIOs, this may explain why RX pin is 0.72V (since it is sinking current through the pull-up on RX). This won't work well, since the RX input will handle this as logic low, and assume there is incomming data, and will quickly assert due to framing errors on the RX pin. My suggestion in this case is that the nRF52840 monitor if the peer device is sufficient powered before init the UART.
    Kenneth
