Hi, I am using custom board. i am facing issue when i am integrating with ble we are facing issue that i2c stopped working. event we are not able to read(scan) slave address.
&i2c1 {
status = "ok";
sda-pin = < 21 >;
scl-pin = < 19 >;
clock-frequency = <I2C_BITRATE_STANDARD>;
&i2c2 {
status = "ok";
sda-pin = < 32 >;
scl-pin = < 33 >;
zephyr,concat-buf-size = <256>;
&i2c3 {
status = "ok";
sda-pin = < 34 >;
scl-pin = < 35 >;
# nothing here ## Print on Segger IDE console CONFIG_STDOUT_CONSOLE=y CONFIG_PRINTK=y CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_UART_CONSOLE=n #CONFIG_LOG=y #CONFIG_LOG_DEFAULT_LEVEL=4 #CONFIG_DEBUG_OPTIMIZATIONS=y #CONFIG_LOG_PRINTK=y # Segger RTT #CONFIG_USE_SEGGER_RTT=y #CONFIG_RTT_CONSOLE=y #CONFIG_UART_CONSOLE=n #CONFIG_LOG_BACKEND_RTT=y #CONFIG_LOG_BACKEND_UART=n # #CONFIG_ASSERT=y #CONFIG_STACK_SENTINEL=y #CONFIG_LOG_PROCESS_THREAD=y # I2C enable CONFIG_I2C=y # GPIO enable CONFIG_GPIO=y #SPI flash CONFIG_NORDIC_QSPI_NOR=y CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_DEBUG=y CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FPU=y CONFIG_FP_HARDABI=y CONFIG_NEWLIB_LIBC=y CONFIG_IDLE_STACK_SIZE=4096
my Pins and .conf file si attached above.
when i am debugging things i found I2C communication is going slower.
