Get a wrong device name when spi flash is mounted
大家好:
 我正在使用 NRF 连接 SDK,nrf916 硬件。
 我同时使用 spi flash 和 mcuboot。这是我的一些配置:
fstab {
		compatible = "zephyr,fstab";
		lfs2: lfs2 {
			compatible = "zephyr,fstab,littlefs";
			mount-point = "/spi_flash";
			partition = <&lfs2_part>;
			read-size = <1>;
			prog-size = <1>;
			cache-size = <128>;
			lookahead-size = <32>;
			block-cycles = <100>;
	&mx25l256 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		lfs2_part: partition@0 {
			label = "spi_flash1";
			reg = <0x00000000 0x00010000>;
flash0: flash@0 {
					compatible = "soc-nv-flash";
					label = "NRF_FLASH";
					erase-block-size = < 0x1000 >;
					write-block-size = < 0x4 >;
					reg = < 0x0 0x100000 >;
					partitions {
						#address-cells = < 0x1 >;
						#size-cells = < 0x1 >;
						boot_partition: partition@0 {
							label = "mcuboot";
							reg = < 0x0 0x10000 >;
static void recreate_file_system(void)
    const struct flash_area *pfa = NULL;
    int                      rc;
    unsigned int             id = (uintptr_t)(m_mp->storage_dev);
    rc                          = flash_area_open(id, &pfa);
    if (rc < 0) {
        LOG_WRN("can't find flash area %lu: %d", id, rc);
        return;
    LOG_ERR("%d '%s'", __LINE__, m_mp->mnt_point);
    LOG_DBG("%d '%s' at 0x%x for 0x%x bytes", __LINE__, pfa->fa_dev_name,
            (unsigned int)pfa->fa_off, (unsigned int)pfa->fa_size);
    /* Optional wipe flash contents */
    if (IS_ENABLED(CONFIG_APP_WIPE_STORAGE)) {
        rc = flash_area_erase(pfa, 0, pfa->fa_size);
        LOG_WRN("%d Erasing flash area ...[0x%x] ?%d", __LINE__, pfa->fa_size,
                rc);
    flash_area_close(pfa);
日志是:
<inf> file_e: recreate_file_system, 85
[00:00:00.230,926] <err> file_e: 94 '/spi_flash'
[00:00:00.231,292] <dbg> file_e.recreate_file_system: 95 'NRF_FLASH_DRV_NAME' at 0x0 for 0xc000 bytes
[00:00:00.231,903] <err> os: Exception occurred in Secure State
[00:00:00.232,757] <err> os: ***** HARD FAULT *****
[00:00:00.233,551] <err> os:   Fault escalation (see below)
[00:00:00.234,375] <err> os: ***** BUS FAULT *****
[00:00:00.235,137] <err> os:   Precise data bus error
[00:00:00.235,931] <err> os:   BFAR Address: 0x50008158
[00:00:00.236,816] <err> os: r0/a1:  0x00000000  r1/a2:  0x20015048  r2/a3:  0xffffffff
[00:00:00.237,976] <err> os: r3/a4:  0x40039000 r12/ip:  0x80000000 r14/lr:  0x0002d7e5
[00:00:00.239,166] <err> os:  xpsr:  0x01000000
[00:00:00.239,990] <err> os: Faulting instruction address (r15/pc): 0x00033a3c
[00:00:00.240,997] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:00:00.242,034] <err> os: Current thread: 0x20015048 (unknown)
挂载点是'/spi_flash',没错。  但是起始地址和大小是 0x0、0xc000 , 它们是mcuboot的。
8080.zephyr.dts
# SEGGER J-Link RTT Viewer V7.54d Terminal Log File
# Compiled: 16:21:51 on Sep 28 2021
# Logging started @ 20 Dec 2021 20:41:58
00> [00:00:00.201,904] <err> spi_nor: Device id c2 20 19 does not match config c2 20 19
00> [00:00:00.203,186] <inf> lis2dh: LIS3DH: int1 on GPIO_0.00
00> [00:00:00.203,613] <inf> lis2dh: LIS3DH: int2 on GPIO_0.01
00> [00:00:00.204,711] <inf> lis2dh: bus=I2C_2 fs=2, odr=0x4 lp_en=0x0 scale=9576
00> [00:00:00.222,442] <inf> littlefs: littlefs partition at /spi_flash
00> [00:00:00.229,248] <inf> main: Cellular Gateway V1.0.0
00> [00:00:00.229,644] <inf> main: reset reason: 0x00010000.
00> [00:00:00.230,041] <inf> db: nvs init...
00> [00:00:00.230,529] <inf> file_e: recreate_file_system, 85
00> [00:00:00.230,926] <err> file_e: 94 '/spi_flash'
00> [00:00:00.231,292] <dbg> file_e.recreate_file_system: 95 'NRF_FLASH_DRV_NAME' at 0x0 for 0xc000 bytes
00> [00:00:00.231,903] <err> os: Exception occurred in Secure State
00> [00:00:00.232,757] <err> os: ***** HARD FAULT *****
00> [00:00:00.233,551] <err> os:   Fault escalation (see below)00:00:00.638,702] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
00> [00:00:00.672,912] <err> os: Current thread: 0x20015048 (unknown)
00> [00:00:00.690,490] [1;31m<err> fatal_error: Resetting system[0m
00>
00> [00:00:00.234,375] <err> os: ***** BUS FAULT *****
00> [00:00:00.235,137] <err> os:   Precise data bus error
00> [00:00:00.235,931] <err> os:   BFAR Address: 0x50008158
00> [00:00:00.236,785] <err> os: r0/a1:  0x00000000  r1/a2:  0x20015048  r2/a3:  0xffffffff
00> [00:00:00.237,976] <err> os: r3/a4:  0x40039000 r12/ip:  0x80000000 r14/lr:  0x0002d7e5
00> [00:00:00.239,166] <err> os:  xpsr:  0x01000000
00> [00:00:00.239,990] <err> os: Faulting instruction address (r15/pc): 0x00033a3c
00> [00:00:00.240,997] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
00> [00:00:00.242,034] <err> os: Current thread: 0x20015048 (unknown)
00> [00:00:00.259,582] [1;31m<err> fatal_error: Resetting system[0m
(Connection lost)
# Logging stopped @ 20 Dec 2021 20:42:09
