Own PWM device with own board not working
I have an own hardware using nRF5340. So I created first an own board in the device tree. I took the definition of the nRF5340 development board and simply removed all the connectors, button, leds that were not on the pure processor. That seems to work. As this definition should be used for other similar boards, I keept all the status at disabled.
In an overlay file of my current project I changed the status now to ok:
   soc {
         peripheral@50000000 {
                     pwm0: pwm@21000 {
                           status = "okay";
In the generated zephyr.dts I see then, that the status is ok. So that works. But I understand some device tree documentation that the following should also work:
    &pwm0 {
       status = "okay";
But pressing then Run CMake in SES I got the errors:
Error: nrf5340_ces_app.dts.pre.tmp:616.9-14 syntax error
FATAL ERROR: Unable to parse input tree
CMake Error at C:/ncs/v1.8.0/zephyr/cmake/dts.cmake:225 (message):
Even not so nice I could live for the moment with the first aproach. But would be nice to get knowledge about the problem and how to make it right.
My main problem is with my beeper. I want to use the pwm moduls together with pin 16 of port 0. So I define a beeper (in the overlay file) as
        beepernode{
             beeper: beepersnode {
                    pwms = < &pwm0 16 >;
Run CMake doesn't give an error and I see this part in zephyr.dts
Following the documentation and the blinky_pwm example I try to use my beeper with
    pwm = DEVICE_DT_GET(DT_PWMS_CTLR(DT_NODELABEL(beeper)));
    if (!device_is_ready(pwm))
            return;
But building is not working and I get the error
4> In file included from C:/ncs/v1.8.0/zephyr/include/toolchain/gcc.h:66,
4>                  from C:/ncs/v1.8.0/zephyr/include/toolchain.h:50,
4>                  from C:/ncs/v1.8.0/zephyr/include/kernel_includes.h:19,
4>                  from C:/ncs/v1.8.0/zephyr/include/kernel.h:17,
4>                  from C:/ncs/v1.8.0/zephyr/include/zephyr.h:18,
4>                  from ../BA_Beschlag.cpp:1:
4> ../BA_Beschlag.cpp: In function 'void main()':
4> C:/ncs/v1.8.0/zephyr/include/device.h:81:39: error: '__device_dts_ord_DT_N_S_beepernode_S_beepersnode_P_pwms_IDX_0_PH_ORD' was not declared in this scope
4> C:/ncs/v1.8.0/zephyr/include/toolchain/common.h:124:26: note: in definition of macro '_DO_CONCAT'
4> C:/ncs/v1.8.0/zephyr/include/device.h:81:31: note: in expansion of macro '_CONCAT'
4> C:/ncs/v1.8.0/zephyr/include/device.h:233:37: note: in expansion of macro 'DEVICE_NAME_GET'
4> C:/ncs/v1.8.0/zephyr/include/device.h:247:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
4> ../BA_Beschlag.cpp:32:11: note: in expansion of macro 'DEVICE_DT_GET'
I tried several changes but can't find my error.
What do I have to do to get my beeper working as pwm device?
Erwin
    Seems like you are lacking the compatible part of the overlay:
        beepernode {
            compatible = "pwm-leds";
                    pwms = < &pwm0 16>;
                    label = "beeper node LED";
    Could you try this and report back?
    Håkon
  • Now I get the linker failure
    undefined reference to `__device_dts_ord_8'
  • here's my overlay, matched to the LEDs on the nrf52dk (file boards/nrf52dk_nrf52832.overlay):
            leds {
                    compatible = "gpio-leds";
                    red_led: led_1 {
                            gpios = <&gpio0 17 0>;
                            label = "RGB red channel";
                    green_led: led_2 {
                            gpios = <&gpio0 18 0>;
                            label = "RGB green channel";
                    blue_led: led_3 {
                            gpios = <&gpio0 19 0>;
                            label = "RGB blue channel";
            pwmleds {
                    red_pwm_led: led_pwm_0 {
                            pwms = <&pwm0 17>;
                            label = "Red PWM LED";
                    green_pwm_led: led_pwm_1 {
                            pwms = <&pwm0 18>;
                            label = "Green PWM LED";
                    blue_pwm_led: led_pwm_2 {
                            pwms = <&pwm0 19>;
                            label = "Blue PWM LED";
            beepernode {
                            pwms = < &pwm0 20>;
                            label = "beeper node";
            aliases {
                    red-pwm-led = &red_pwm_led;
                    green-pwm-led = &green_pwm_led;
                    blue-pwm-led = &blue_pwm_led;
    &pwm0 {
            status = "okay";
            ch0-pin = <17>;
            ch1-pin = <18>;
            ch2-pin = <19>;
            ch3-pin = <20>;
    This is the overlay for the zephyr/samples/basic/rgb_led sample to work with the DK, where I just added your beepernode as a 4th channel on the pwm0 instance.
    Håkon
  • I changed now my example to really use a LED that is connected to Pin24 of Port 0. So no Beeper, even praktically it shouldn't be a real difference.
    The overlay file is:
            leds {
                    red_led: led_1 {
                            gpios = <&gpio0 24 0>;
            pwmleds {
                            pwms = <&pwm0 24>;
            aliases {
    &pwm0 {
            status = "okay";
            ch0-pin = <24>;
    My main function (in a c++ file, so with ending cpp) is now simple:
    #include <zephyr.h>
    #include <device.h>
    #include <drivers/pwm.h>
    const struct device* pPwm;
    void main(void)
        pPwm = DEVICE_DT_GET(DT_NODELABEL(red_pwm_led));
        if (!device_is_ready(pPwm))
                return;
        if (pwm_pin_set_usec(pPwm, DT_PWMS_CHANNEL(DT_NODELABEL(red_pwm_led)), 200, 100, DT_PWMS_FLAGS(DT_NODELABEL(red_pwm_led))))
                return;
    running CMake works but when I build all I got the warning
    undefined reference to `__device_dts_ord_14'
    So it still doesn't work.
  • Here's my test project, added cpp as well:
    rgb_led.zip
    Note: I'm testing with another board, but that should not matter as long as you rename the .overlay to your board.
    Håkon
