Which mesh technology for sending custom payloads?
Hi all,
I am working on an electronic lock using the nRF52840. Currently it works using Bluetooth Low Energy and the lock opens when a digital key has been sent. (it has measures against replay attacks, tampering with the payload and ensures the "digital key" is coming from my API). It has a characteristic to which a payload can be written. It also has a characteristic where it notifies the response to a payload to the connected central.
I am now looking for a way to implement mesh networking to increase range and use a lot of devices (most centrals can handle up to ~9 BLE connections). I would like to use a Zigbee or Bluetooth dongle with a raspberry Pi to send messages into the mesh network.
I use some Zigbee devices at home so I've been looking at that first, but after having a look at the Zigbee Cluster Libary Specification (page 399) it seems like I'm forced to change the way the entire product works. Basically what I would like to expose to the network is the following:
Input:
char[500] - used for payloads to open / configure the lock ( a payload can be retrieved from my API and sent to the correct lock )
Output:
char[500] - used to send responses generated by parsed payloads? Maybe there is a better way to return responses?
bool - lock mechanism state (locked/unlocked)
uint8_t - temperature (in degrees celsius)
(maybe more sensor data in the future)
I am looking into the
nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8/examples/multiprotocol/ble_zigbee/ble_zigbee_dynamic_door_lock_nus/
example, but as far as I understand a boolean is simply set to open or close the lock. I'm still struggling to understand if what I want is possible with Zigbee and if it is allowed at all? If it is not possible or recommended to use Zigbee for this, would Bluetooth Mesh be a possible alternatives, or are these mesh technologies simply not capable of handling those amounts of data?
Thanks a lot for reading all the way through and I hope someone is able to clear it up a bit Slight smile
    Since it is the holiday season, we are a bit understaffed and the experts in the field are out of office. So please expect a delay.
    Swathy
    Sorry to keep you waiting. As I mentioned, we are a bit understaffed right now. I discussed your case with the experts. It is possible to implement what you require using zigbee taking this example as a base for development. To implement the particular set of requirements in your project, you need to implement clusters for the sensors and use attributes for reading characteristics. Be aware that you'll need to create something very different with zigbee than the one you created with ble.
    Kind Regards,
    Swathy
