Cannot capture high-speed GPIOTE interrupts
Hello, I tried to use pin_change_example in SDK to catch Interrupts (at first line) but I'm missing lots of them.
How can I catch all the interrupt events without delay?
At present, I am using the ble_app_uart template.
This is the code of GPIOTE init and handler functions
void DRDY_pin_handle(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
//nrf_gpio_pin_toggle(RST2);
drdy_3 = !drdy_3;
nrf_gpio_pin_set(RST2);
__nop();
nrf_gpio_pin_clear(RST2);
void ADS127L01_GPIO_Init(void)
// Reset OUTPUT Config
nrf_gpio_cfg_output(RST3);
nrf_gpio_pin_clear(RST3);
// Start Output Config
nrf_gpio_cfg_output(START3);
nrf_gpio_pin_clear(START3);
// NCS Output Config
nrf_gpio_cfg_output(NCS3);
nrf_gpio_pin_clear(NCS3);
// GPIO config for testing
nrf_gpio_cfg_output(RST2);
// DRDY Input Config
// nrf_gpio_cfg_input(DRDY3, NRF_GPIO_PIN_NOPULL);
ret_code_t err_code; // hold error value
nrf_drv_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_HITOLO(true); // Falling edge interrupt detection
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(DRDY3, &in_config, DRDY_pin_handle); // Initialize the interrupt pin
nrf_drv_gpiote_in_event_enable(DRDY3, true); // Enable the interrupt events
  • Perhaps there is something else in your application that is running on a higher or same priority that takes up the time in every 3rd event? Try disabling everything but the pin interrupt and see if it picks up more than 1 in 3 events.
    This being said, if you intend to use the softdevice for Bluetooth, and you want to get all of these events, it will be very tricky using this bit-banging. You will at certain points have the softdevice using the CPU for more than 4µs. As mentioned, up to several milliseconds if you are sending a lot of data. You should consider using the PPI for this. It is a bit tricky to understand at first, but if you like, you can check out the hands-on that I used at some point in time:
    https://github.com/edvinand/ppi_pwm_hands_on
    (solution in the src folder). If you are using the nRF5 SDK, just copy paste the main file into any example from the SDK, remove the printk() and replace the k_sleep() with nrf_delay_ms() (#include "nrf_delay.h").
    PS: We are short staffed due to Christmas Holidays, so we expect some delay in our response time. I will be out of office from tomorrow until the beginning of January.
