ERROR: The file specified is not a valid hex file, has data outside valid areas
Hello, when i try to flash my card, (nrf52840) in visual studio code i have those errors
ERROR: or does not have data in valid areas.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 52: nrfjprog --program 'c:\Users\l.marcos\Documents\nordictests\peripheral_uart\build_1\zephyr\zephyr.hex' --sectoranduicrerase -f NRF52 --snr 683372301
Thank you in advance for the help
best regards
  • and look what i have when i try to build.
    From the snippet I can see that you are configuring for a nrf52dk_nrf52805.
    But you said that you have only a nrf52840DK? (And in the connected devices section it shows that you have connected a nrf52840DK)
    I guess that you are still not familiar with the basics and I would emphasize on building ad running a normal DK first before moving onto the BC805 (I understand that this is a crucial module).
    Every application has a set of DK that it supports. For the peripheral_uart sample, when you begin the VS Code page, and give the build configuration, you cannot select a different board name other than the one you are using, for eg, if you are using an nrf52840DK, then you have to select somewhat like this:
    Only if you have an nrf52dk_nrf52805 (an nrf52dk with a nrf52805 chip on it) can you select the board as nrf52dk_nrf52805. Also, in the peripheral_uart example, this board is not supported, hence I am not sure whether it will work either.
    You should try using the nrf52840DK and learn how this works and also learn a few basics which can be helpful in future.
    Priyanka
  • hi,
    What you dont understand is that i have THEmodule yes, i already tested with simples DK it already worked with nrf52840and his config.
    i'm using simple DK and everything worked fine until now with this new module. My only request was to help me with the errors that i have with my module... during the build and my incapacity to flash this with the right build configurations parameters.
  • If with this module this is not possible do you an alternative module connection that i can make with a module BLE from nordic? That will accept the build and flash? thx in advance
