Using the UART2 with MQTT client
I'm using an application based on the MQTT_CLIENT example. Without any change, it worked fine.
Now I tried to add UART2 as a communication channel to another controller.
Following is my added code:
void uart_cb(struct device *x)
    uart_irq_update(x);
    int data_length = 0;
    if (uart_irq_rx_ready(x))
        if (uart_irq_update(x))
            data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
            uart_buf[data_length] = 0;
    if (uart_irq_tx_ready(x))
        //const struct uart_driver_api *api =(const struct uart_driver_api *)x->api;
        //api->fifo_fill(x, uart_buf, 1);
        //api->tx(dev, buf, len, timeout);
        //uart_tx(x, uart_buf, 1,0);
    //if (uart_irq_tx_ready(x))
    //printk("%s", uart_buf);
and in main() function:
    const struct device *uart2 = device_get_binding((const char *)"UART_2");
    struct uart_config cfg;
    cfg.baudrate = 115200;
    cfg.parity = UART_CFG_PARITY_NONE;
    cfg.stop_bits = UART_CFG_STOP_BITS_1;
    cfg.data_bits = UART_CFG_DATA_BITS_8;
    cfg.flow_ctrl = UART_CFG_FLOW_CTRL_NONE;
    uart_configure(uart2, &cfg);
    uart_irq_callback_set((const struct device *)uart2, (uart_irq_callback_user_data_t)uart_cb);
    uart_irq_rx_enable(uart2);
    uart_irq_tx_enable(uart2);
Any idea?
10x, Uri.
