How to remap bootloader and application flash area in overlay file
Board :52840dk_52840
SDK: NCS1.7.1
IDE :Visual Studio Code
I remap my bootloader partition in my application .overlay file
as
        &boot_partition{
            reg = <0x000000000 0x00010000>;
        &slot0_partition {
            reg = <0x00010000 0x00063000>;
but I get the this result in zephyr.dts, the beginning of slot0 did NOT change to 0x10000
                    boot_partition: partition@0 {
                        label = "mcuboot";
                        reg = < 0x0 0x10000 >;
                    slot0_partition: partition@c000 {
                        label = "image-0";
                        reg = < 0x10000 0x63000 >;
and my mcuboot build result is as following, the bootloader area size was still 48KB
Memory region         Used Size  Region Size  %age Used
           FLASH:       30984 B        48 KB     63.04%
            SRAM:       17760 B       256 KB      6.77%
        IDT_LIST:          0 GB         2 KB      0.00%
It seems like that my bootloader remap is a failure .
my quesion is
1# can I remap bootloader and application flash area in .overlay file
2# how to remap bootloader and application flash area in .overlay file
    You should use the partition manager for this purpose and define a static partition:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/scripts/partition_manager/partition_manager.html#static-configuration
    Here's an example on expanding the specific section:
    https://github.com/nrfconnect/sdk-nrf/blob/v1.8.0/applications/machine_learning/configuration/nrf5340dk_nrf5340_cpuapp/pm_static.yml#L5-L8
    PS: a full partition layout is available after you configure you project in "build-folder/partitions.yml" - this file can be copied to pm_static.yml and modified per your needs.
    Håkon
  • I use these settings in .conf  filefor my mcuboot building
    CONFIG_LOG=y
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    # The build won't fit on the partition allocated for it without size
    # optimizations.
    CONFIG_SIZE_OPTIMIZATIONS=y
    # Serial
    CONFIG_SERIAL=y
    CONFIG_UART_LINE_CTRL=y
    # MCUBoot serial
    CONFIG_MCUBOOT_SERIAL=y
    CONFIG_BOOT_SERIAL_CDC_ACM=y
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_BACKEND_RTT=n
    and I got my partitions.yml as following
    app:
    address: 0x10200
    end_address: 0x88000
    region: flash_primary
    mcuboot:
    address: 0x0
    end_address: 0x10000
    placement:
    before:
    - mcuboot_primary
    mcuboot_pad:
    address: 0x10000
    end_address: 0x10200
    placement:
    align:
    start: 0x1000
    before:
    - mcuboot_primary_app
    mcuboot_primary:
    address: 0x10000
    orig_span: &id001
    - mcuboot_pad
    - app
    sharers: 0x1
    span: *id001
    mcuboot_primary_app:
    address: 0x10200
    orig_span: &id002
    - app
    span: *id002
    mcuboot_secondary:
    address: 0x88000
    end_address: 0x100000
    placement:
    after:
    - mcuboot_primary
    align:
    start: 0x1000
    share_size:
    - mcuboot_primary
    sram_primary:
    address: 0x20000000
    end_address: 0x20040000
    region: sram_primary
    this is my build result
    [204/204] Linking C executable zephyr\zephyr.elf
               FLASH:       63340 B        64 KB     96.65%
                SRAM:       33440 B       256 KB     12.76%
    [149/164] Linking C executable zephyr\zephyr_prebuilt.elf
    [156/164] Linking C executable zephyr\zephyr.elf
               FLASH:       20124 B     491008 B      4.10%
                SRAM:        7424 B       256 KB      2.83%
    [160/164] Generating ../../zephyr/dfu_application.zip
    [162/164] No install step for 'mcuboot_subimage'
    [163/164] Completed 'mcuboot_subimage'
    [164/164] Generating zephyr/merged.hex
    I think I have remap my bootloader flash area successfully
    but when I flash my board with merged.hex and reset my board
    I got these error log :
    [14:33:11.346]收←◆*** Booting Zephyr OS build v2.6.99-ncs1-1-15-g0710acdc35e7  ***
    I: Starting bootloader
    W: Failed reading sectors; BOOT_MAX_IMG_SECTORS=128 - too small?
    W: Cannot upgrade: not a compatible amount of sectors
    E: Unable to find bootable image
    what's the reason fail to boot into application ??
    I'm not able to reproduce this behavior on my end.
    I have a similar partition layout:
    ninja partition_manager_report
    [1/1] cd /opt/ncs/zephyr/samples/2...amples/281606/build/partitions.yml
      flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0x10000 - 64kB)                    |
    +---0x10000: mcuboot_primary (0x78000 - 480kB)-----+
    | 0x10000: mcuboot_pad (0x200 - 512B)              |
    +---0x10200: mcuboot_primary_app (0x77e00 - 479kB)-+
    | 0x10200: app (0x77e00 - 479kB)                   |
    | 0x88000: mcuboot_secondary (0x78000 - 480kB)     |
      sram_primary (0x40000 - 256kB):
    | 0x20000000: sram_primary (0x40000 - 256kB) |
    Here's the sample:
    281606.zip
    Could you try this and see if the behavior is still equal on your end?
    PS: I see that your zephyr boot banner indicates that you are on a non-tagged version. Could you repeat testing on ncs v1.7.x or ncs v1.8.0?
    Håkon
  • Hi Håkon
    I still have the same issue using your sample.
    And I am using NCS 1.7.1
    Best regards
    Sky Lu
    I tested both ncs v1.7 and ncs v1.8 with my example, and I cannot recreate the issue you are seeing. Can you please try to delete the build folder and re-generate the project?
    Håkon
