Issues with creating multiple TLS server
Hi Nordic team,
Our requirement is creating two TLS server with same IP and different port no, but when I try to bind two servers only one server is getting bind to the network but other server is not binding
getting error no as 116 in bind API, here I am using two threads one for each server.
If I try with normal TCP multiple server it is working fine I am able to setup both the servers, why it is failing with the TLS server, please guide us on this.
Best Regards
Anitha S
  • Yes I will share snippets of my code
    int socketCreate(uint8_t ip_version,int *sock_fd)
    uint8_t err;
    if(ip_version == 4)
    /*Creating the IPV4 socket NRF_SPROTO_TLS1v2 */
    *sock_fd = nrf_socket(NRF_AF_INET,NRF_SOCK_STREAM, NRF_SPROTO_TLS1v2);
    if (*sock_fd < 0)
    printk("error in creating the socket\n");
    return errno;
    int certProvision(void)
    int err;
    bool exists;
    uint8_t unused;
    if ((err = modem_key_mgmt_exists(TLS_SEC_TAG,MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,&exists, &unused)) < 0)
    printk("Failed to check for certificates err %d\n", err);
    return err;
    if (exists)
    /* For the sake of simplicity we delete what is provisioned
    * with our security tag and reprovision our certificate.
    if ((err = modem_key_mgmt_delete(TLS_SEC_TAG,MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN)) < 0)
    printk("Failed to delete existing certificate, err %d\n",
    err);
    return err;
    printk("Provisioning certificate\n");
    /* Provision certificate to the modem */
    if ((err = modem_key_mgmt_write(TLS_SEC_TAG,MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,CA_cert, sizeof(CA_cert) - 1))<0) //Provisioning CA certificate
    printk("Failed to provision certificate, err %d\n", err);
    return err;
    if ((err = modem_key_mgmt_write(TLS_SEC_TAG,MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT,S_cert, sizeof(S_cert) - 1)) < 0) //Provisioning server certificate
    printk("Failed to provision server cert, err %d\n", err);
    return err;
    if ((err = modem_key_mgmt_write(TLS_SEC_TAG,MODEM_KEY_MGMT_CRED_TYPE_PRIVATE_CERT,pr_key, sizeof(pr_key) - 1)) < 0) //Provisioning server private key
    printk("Failed to provision server private key, err %d\n", err);
    return err;
    return TLS_SUCCESS;
    int tlsCredentialAdd()
    int err;
    // Security tag that we have provisioned the certificate with
    if((err = tls_credential_add(tls_sec_tag[0],TLS_CREDENTIAL_CA_CERTIFICATE,CA_cert,sizeof(CA_cert))) < 0) //adding CA certificate credentials
    printk("erro in tls_add()\n");
    return err;
    if((err = tls_credential_add(tls_sec_tag[0],TLS_CREDENTIAL_SERVER_CERTIFICATE,S_cert,sizeof(S_cert))) < 0) //adding server certificate credentials
    return err;
    if((err = tls_credential_add(tls_sec_tag[0],TLS_CREDENTIAL_PRIVATE_KEY,pr_key,sizeof(pr_key))) < 0) //adding server private key credentials
    return err;
    return 0;
    int tlsSetup(int fd)
    int err;
    int verify;
    /* Security tag that we have provisioned the certificate with */
    int opt = 1;
    /* setting TLS role as server */
    if ((err = nrf_setsockopt(fd, NRF_SOL_SECURE, NRF_SO_SEC_ROLE,&opt,sizeof(opt)))<0)
    printk("T1 Failed to setup role, err %d\n", errno);
    return err;
    // verify = REQUIRED;
    /* setting Peer verification */
    verify = NONE;
    if ((err = nrf_setsockopt(fd, NRF_SOL_SECURE,NRF_SO_SEC_PEER_VERIFY, &verify, sizeof(verify))) < 0)
    printk("T1 Failed to setup peer verification, err %d\n", errno);
    return err;
    /* Associate the socket with the security tag
    * we have provisioned the certificate with.
    if ((err = nrf_setsockopt(fd, NRF_SOL_SECURE, NRF_SO_SEC_TAG_LIST, tls_sec_tag,sizeof(tls_sec_tag))) < 0) {
    printk("T1 Failed to setup TLS sec tag, err %d\n", errno);
    return err;
    return TLS_SUCCESS;
    Please suggest some solution for my actual question.
    best regards
  • Thanks for the code.
    Note that when you are using native TLS (which you must to have a TLS server), you must use Zephyr's sockets, not nrf_sockets.
    I've attached a project that opens and binds and listens to two TLS sockets.
    Note that I am not able to test if it actually can connect to clients, because of limitations with my SIM card.
    dual_tls_server.zip
  • Thank you Didrik I am able to bind both server.
    best regards
  • Hi Didrik,
    we are able to bind two TLS server, but not able to accept clients on the two server at the same time, we are able to accept only one client ,for other server we are getting error while accepting (error no:12).
    we are using threads to implement two servers. Please guide us on this.
    best regards
  • Because of limitation s with my SIM cards, I am not really able to reproduce this.
    So, could you take a modem trace, so I can see if the error comes from the modem or the application?
