Issues with creating multiple TLS server
Hi Nordic team,
Our requirement is creating two TLS server with same IP and different port no, but when I try to bind two servers only one server is getting bind to the network but other server is not binding
getting error no as 116 in bind API, here I am using two threads one for each server.
If I try with normal TCP multiple server it is working fine I am able to setup both the servers, why it is failing with the TLS server, please guide us on this.
Best Regards
Anitha S
    The DevZone support team is currently lower staffed due to Christmas holiday. Please expect longer response time.
    Can you please provide what version of nRF Connect SDK you are using?
    Are you doing this in the Serial LTE Modem? The documentation states: The TLS server role is currently not supported.
    Øyvind
    We are using nrf connect sdk 1.7.0, and I am not using Serial LTE Modem example.
  • Are you able to provide more information i.e. are you basing this on a special sample, are you using native TLS? What modem FW are you using on the device? This is relevant for me to reproduce the issue.
    Øyvind
  • I am not using any sample this is my own project, yes we are using native TLS and modem version is mfw_nrf9160_1.3.1.
    below is my prj.conf
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # AT host library
    CONFIG_AT_HOST_LIBRARY=y
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=3072
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    #LTE
    CONFIG_MODEM_KEY_MGMT=y
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    CONFIG_NEWLIB_LIBC=y
    #CONFIG_POSIX_MAX_FDS = 8
    #CONFIG_ASSERT=y
    #mbedtls and security
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    CONFIG_NET_SOCKETS_OFFLOAD_TLS=n
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096
    CONFIG_MBEDTLS_HEAP_SIZE=32768
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_MBEDTLS_PKCS1_V15=y
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    CONFIG_MBEDTLS_SHA1_C=y
    CONFIG_NRF_SECURITY_ADVANCED=y
    CONFIG_NORDIC_SECURITY_BACKEND=y
    Please tell us what is issue with multiple TLS server.
    Thank you
    Anitha S
    We are a bit short on capacity this week due to Christmas vacations, but I'll try to help you as best as I can.
    Could you share some snippets of your code showing how you create the sockets, and how you use them?
    Didrik
