how many nRF24L01+ RF tranceivers in a network
A friend of mine asked me to help with thinking about a solution to create a RF communication between 8 robots and 1 access point. Not a lot of traffic, just to signal that the robot is (almost) at the end of his track and get some control information. once per few minutes. This is not very complicated and I was thinking about the nRF24L01+ chip with external antenna. We need a range of approx. 100 - 150 meter. LOS
the complex part is the following: it is used in a field with solar panels, and we need about 4000 robots and 4000/8 = 500 access points.
So each access point with 8 robots is actually a small network. But because all of these networks are in the same field (not all of them are discoverable) I need to have multiple network ID's and unique ID's for each RF tranceiver, right?
Is this feasible with this amount of tranceivers?
Jasper
  • Hi Jasper,
    Are you concerned about noise between the different centrals? If you have a configuration that is something like this:(* is a robot and C is an access point)
    * C * * C *
    * C * * C *
    Then the distance between robots that are transmitting different network ids and the closest access point with a different network id would be 200-300m based on the way I am reading your post.
    To get a range of 100-150m reliably with the nRF24L01+ you will need to use a power amplifier(PA) or a low noise amplifier(LNA). Since you are able to control the effect that you transmit you will be able to tune your system so that you can "hear" a robot/access point that is within your 100-150m range, but not within the 200-300m range, i.e. the loss is so high for ranges over 200m that the robots appear to be invisible.
    I might be interpreting your question incorrectly, please elaborate if so.
    Øyvind
  • nRF51 should have more processing power than I need. I was planning to use a ATMega328. But the nRF51 can do the job...
