Enable event lenght extension on sdk 1.7.0
I am trying to enable event length extension on uart example provided on the sdk. I look for information on how to done it and i found links like that:
https://devzone.nordicsemi.com/f/nordic-q-a/22698/setting-gap-connection-event-length---ble-hrs-c-demo
https://devzone.nordicsemi.com/f/nordic-q-a/39787/verifying-connection-event-length-extension-and-data-length-extension
But on sdk 1.7.0 i am not able to do it because of there are many dependences that i can't find. On addition, is necessary to reproduce the code of links have an sttack declared and initialized on main.c, and this isn't occur on uart peripheral example.
Please if somebody could explain to me step by step what requirements i need to enable this event length extension? And there are some Kconfig to do it directly?? or is necessary to initialize the stack dinamically on main.c and pass the configuration necessary?
I know that on nrf528xx-ble-throughput-demo this is done, butim not able to reproduce t on the actual sdk.
I will be very gratefull,
regards.
    I see a similar implementation on another example, could you check that this is correct?
    static int EvtLen(void)
            int err;
    	struct net_buf *buf;
    	sdc_hci_cmd_vs_conn_event_extend_t *evt_enable;
    	buf = bt_hci_cmd_create(SDC_HCI_OPCODE_CMD_VS_CONN_EVENT_EXTEND,
    				sizeof(*evt_enable));
    	if (!buf) {
    		printk("Could not allocate LLPM command buffer\n");
    		return -ENOMEM;
            evt_enable = net_buf_add(buf, sizeof(*evt_enable));
    	evt_enable->enable = 2;
    	err = bt_hci_cmd_send_sync(SDC_HCI_OPCODE_CMD_VS_CONN_EVENT_EXTEND, buf, NULL);
    	if (err) {
    		printk("Error enabling EVENT %d\n", err);
    		return err;
    	printk("EVENT mode enabled\n");
    	return 0;
  • could it be the 'dynamic event length' is already enabled by default in the throughput example?
