nrf connect sdk 'fatal error: opening dependency file'
> Executing task: nRF Connect: Generate config nrf52dk_nrf52832 for Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC <
Building Hoeflon_Innovations-Bluetooth_POC
west build --build-dir c:\Users\MartijnJonkers\Documents\Development\Hoeflon_Innovations\Hoeflon_Innovations-Bluetooth_POC\Hoeflon_Innovations-Bluetooth_POC\build-nrf52_dk c:\Users\MartijnJonkers\Documents\Development\Hoeflon_Innovations\Hoeflon_Innovations-Bluetooth_POC\Hoeflon_Innovations-Bluetooth_POC --pristine --board nrf52dk_nrf52832 -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE"
Including boilerplate (Zephyr base): C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC
-- Zephyr version: 2.7.0 (C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1
-- Found Python3: C:/Users/MartijnJonkers/ncs/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf52dk_nrf52832
-- Cache files will be written to: C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/.cache
-- Found dtc: C:/Users/MartijnJonkers/ncs/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/Users/MartijnJonkers/ncs/v1.8.0/toolchain/opt)
-- Found BOARD.dts: C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
-- Found devicetree overlay: dts.overlay
-- Generated zephyr.dts: C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/dts.cmake
Parsing C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/Kconfig
Loaded configuration 'C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
Merged configuration 'C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/prj.conf'
Configuration saved to 'C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/.config'
Kconfig header saved to 'C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Users/MartijnJonkers/ncs/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
CMake Warning at C:\Users\MartijnJonkers\ncs\v1.8.0\zephyr\CMakeLists.txt:1662 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk
[1/217] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/217] Generating include/generated/driver-validation.h
[3/217] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[4/217] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[5/217] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[6/217] Generating include/generated/offsets.h
[7/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[8/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
[9/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
[10/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_uart.c.obj
[11/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
[12/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
[13/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
[14/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
[15/217] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
[16/217] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/MartijnJonkers/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/C_/Users/MartijnJonkers/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj
C:\Users\MartijnJonkers\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.7.0-ncs1 -DKERNEL -DNRF52832_XXAA -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/kernel/include -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/arch/arm/include -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrf/drivers/mpsl/clock_control -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/include -Izephyr/include/generated -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/lib/util/fnmatch/. -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/subsys/bluetooth -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrf/include -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrf/lib/multithreading_lock/. -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrf/subsys/bluetooth/controller/. -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/hal/nordic/nrfx -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/include -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/hal/nordic/nrfx/mdk -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/modules/hal_nordic/nrfx/. -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/debug/segger/SEGGER -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/debug/segger/Config -IC:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/modules/segger/. -IC:/Users/MartijnJonkers/ncs/v1.8.0/modules/crypto/tinycrypt/lib/include -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrfxlib/mpsl/include -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrfxlib/mpsl/include/protocol -IC:/Users/MartijnJonkers/ncs/v1.8.0/nrfxlib/softdevice_controller/include -isystem C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/lib/libc/minimal/include -isystem c:/users/martijnjonkers/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/martijnjonkers/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -Os -imacros C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC/build-nrf52_dk/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -imacros C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/MartijnJonkers/Documents/Development/Hoeflon_Innovations/Hoeflon_Innovations-Bluetooth_POC/Hoeflon_Innovations-Bluetooth_POC=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/MartijnJonkers/ncs/v1.8.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/MartijnJonkers/ncs/v1.8.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir/C_/Users/MartijnJonkers/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj -MF zephyr\CMakeFiles\zephyr.dir\C_\Users\MartijnJonkers\ncs\v1.8.0\modules\crypto\tinycrypt\lib\source\cmac_mode.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/C_/Users/MartijnJonkers/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj -c C:/Users/MartijnJonkers/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c
C:\Users\MartijnJonkers\ncs\v1.8.0\modules\crypto\tinycrypt\lib\source\cmac_mode.c:254:1: fatal error: opening dependency file zephyr\CMakeFiles\zephyr.dir\C_\Users\MartijnJonkers\ncs\v1.8.0\modules\crypto\tinycrypt\lib\source\cmac_mode.c.obj.d: No such file or directory
I have installed the v1.8.0 nrf connect sdk and created a new application using the nrf connect vscode extension based on the ble/throughput example. Created a build configuration with the nrf52dk_nrf5252832 board.
But now I do get the error as seen above, I cannot work out what is wrong. Can anyone help me?
Thank you.
