nRF21540DK as Thread RCP
I have a running thread network now. Yay!
I am using a BMD-341 module from a old board as a Thread Sleeping end device. Getting great results.
I've flashed the module with the mqttsn_sleepy_subscriber example from nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8.
I am running the OTBR Docker Container on a Raspberry Pi. I've hooked up a nRF21540DK with the usb interface.
For the nRF21540DK I am Currently using the ot-rcp firmware built with the https://github.com/openthread/ot-nrf528xx repo. However I am having some trouble with getting the FEM to work. I am getting -70dBm RSSI measurements with a distance of 10cm. I know this is a problem with the FEM configuration. I've also made a github issue about getting the nRF21540DK working with ot-rcp.
I tried to build RCP firmware using the CoProcessor Example in the nRF Connect SDK v1.7.1. The firmware is running but the container does not connect with the device. I am hoping someone here knows why this example does not run with the OTBR Docker Container.
nRF21540DK RTT Logs:
[00:00:00.002,868] <inf> ieee802154_nrf5: nRF5 802154 radio initialized
[00:00:00.003,662] <inf> net_otPlat_uart: Waiting for host to be ready to communicate
[00:00:00.007,629] <inf> usb_cdc_acm: Device suspended
[00:00:00.304,412] <inf> usb_cdc_acm: Device resumed
[00:00:00.304,412] <inf> usb_cdc_acm: from suspend
[00:00:00.551,055] <inf> usb_cdc_acm: Device configured
[00:00:00.002,899] <inf> ieee802154_nrf5: nRF5 802154 radio initialized
[00:00:00.003,692] <inf> net_otPlat_uart: Waiting for host to be ready to communicate
[00:00:00.007,659] <inf> usb_cdc_acm: Device suspended
[00:00:00.246,307] <inf> usb_cdc_acm: Device resumed
[00:00:00.246,307] <inf> usb_cdc_acm: from suspend
[00:00:00.490,844] <inf> usb_cdc_acm: Device configured
OTBR Docker Container logs:
+ service tayga start
 * Starting userspace NAT64 tayga
[ OK ]
+ dns64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DNS64
+ local value
++ printenv DNS64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
++ _detect_service_name
++ dpkg -L bind9
++ grep /etc/init.d/
++ cut -d/ -f4
+ service_name=bind9
+ have systemctl
+ command -v systemctl
+ command -v service
/usr/sbin/service
+ sudo service bind9 start
 * Starting domain name service... bind9
[ OK ]
+ firewall_start
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ service otbr-firewall start
+ have systemctl
+ have service
+ sudo service rsyslog status
 * rsyslogd is not running
+ sudo service rsyslog start
 * Starting enhanced syslogd rsyslogd
[ OK ]
+ sudo service dbus status
 * dbus is not running
+ sudo service dbus start
 * Removing stale PID file /var/run/dbus/pid.
 * Starting system message bus dbus
[ OK ]
+ sudo service mdns status
Usage: /etc/init.d/mDNS {start|stop|reload|restart}
+ sudo service mdns start
Starting Apple Darwin Multicast DNS / DNS Service Discovery daemon: mdnsd.
+ sudo service avahi-daemon status
Process 212 died: No such process; trying to remove PID file. (/run/avahi-daemon//pid)
Avahi mDNS/DNS-SD Daemon is not running
+ sudo service avahi-daemon start
 * Starting Avahi mDNS/DNS-SD Daemon avahi-daemon
[ OK ]
+ sudo service otbr-agent status
 * otbr-agent is not running
+ sudo service otbr-agent start
 * Removing stale PID file /var/run/otbr-agent.pid.
 * Starting thread border agent otbr-agent
[ OK ]
+ without WEB_GUI
+ with WEB_GUI
+ local value
++ printenv WEB_GUI
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ sudo service otbr-web status
 * otbr-web is not running
+ sudo service otbr-web start
 * Removing stale PID file /var/run/otbr-web.pid.
 * Starting thread web interface otbr-web
[ OK ]
+ . /dev/null
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: New relevant interface lo.IPv4 for mDNS.
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: Network interface enumeration completed.
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: Registering new address record for fe80::42:acff:fe11:3 on eth0.*.
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: Registering new address record for 172.17.0.3 on eth0.IPv4.
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: Registering new address record for ::1 on lo.*.
Dec 23 16:14:46 6f42ccb377d4 avahi-daemon[212]: Registering new address record for 127.0.0.1 on lo.IPv4.
Dec 23 16:14:46 6f42ccb377d4 rsyslogd: rsyslogd's groupid changed to 101
Dec 23 16:14:46 6f42ccb377d4 rsyslogd: rsyslogd's userid changed to 101
Dec 23 16:14:46 6f42ccb377d4 rsyslogd:  [origin software="rsyslogd" swVersion="8.32.0" x-pid="141" x-info="http://www.rsyslog.com"] start
Dec 23 16:14:47 6f42ccb377d4 avahi-daemon[212]: Server startup complete. Host name is 6f42ccb377d4.local. Local service cookie is 1282487036.
Dec 23 16:14:47 6f42ccb377d4 otbr-agent[248]: [INFO]-UTILS---: Running 0.3.0-72fa16e
Dec 23 16:14:47 6f42ccb377d4 otbr-agent[248]: [INFO]-UTILS---: Thread version: 1.2.0
Dec 23 16:14:47 6f42ccb377d4 otbr-agent[248]: [INFO]-UTILS---: Thread interface: wpan0
Dec 23 16:14:47 6f42ccb377d4 otbr-agent[248]: [INFO]-UTILS---: Backbone interface: eth0
Dec 23 16:14:47 6f42ccb377d4 otbr-agent[248]: [INFO]-UTILS---: Radio URL: spinel+hdlc+uart:///dev/ttyACM0
Dec 23 16:14:47 6f42ccb377d4 otbr-web[284]: [INFO]-WEB-----: Running 0.3.0-72fa16e
Dec 23 16:14:47 6f42ccb377d4 otbr-web[284]: [INFO]-WEB-----: Border router web started on wpan0
Dec 23 16:14:47 6f42ccb377d4 otbr-web[284]: [ERR ]-WEB-----: OpenThread daemon is not running.
Dec 23 16:14:48 6f42ccb377d4 kernel: [279825.427236] usb 1-1.2: new full-speed USB device number 43 using dwc_otg
Dec 23 16:14:48 6f42ccb377d4 kernel: [279825.571170] usb 1-1.2: New USB device found, idVendor=1915, idProduct=0000, bcdDevice= 2.06
Dec 23 16:14:48 6f42ccb377d4 kernel: [279825.571196] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 23 16:14:48 6f42ccb377d4 kernel: [279825.571211] usb 1-1.2: Product: Thread Co-Processor
Dec 23 16:14:48 6f42ccb377d4 kernel: [279825.571226] usb 1-1.2: Manufacturer: Nordic Semiconductor ASA
Dec 23 16:14:48 6f42ccb377d4 kernel: [279825.573885] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
Dec 23 16:14:49 6f42ccb377d4 otbr-agent[248]: 52d.22:46:33.546 [CRIT]-PLAT----: HandleRcpTimeout() at ../../third_party/openthread/repo/src/lib/spinel/radio_spinel_impl.hpp:2218: RadioSpinelNoResponse
Offtopic but sharing this information because I did not see that much info about thread networks, my Power Profiler Kit current measurements and pings over Thread:
Poll rate Power consumption average over 1m41s
	100ms 295uA
	200ms 145uA
	300ms 95uA
		100 packets transmitted, 98 packets received. Packet loss = 2.0%. Round-trip min/avg/max = 52/204.724/582 ms.
	400ms 73uA
		100 packets transmitted, 99 packets received. Packet loss = 1.0%. Round-trip min/avg/max = 20/214.585/542 ms.
	500ms 63uA
		100 packets transmitted, 95 packets received. Packet loss = 5.0%. Round-trip min/avg/max = 63/320.589/818 ms.
	1000ms 33uA
        100 packets transmitted, 96 packets received. Packet loss = 4.0%. Round-trip min/avg/max = 109/624.541/2101 ms.
    Using the CoProcessor Example with nRF Connect SDK should be the best way to use the nRF21540DK, as I can not see any builds for the nRF21540DK in the openthread github repository.
    When the nRF Connect SDK CoProcessor sample does not work with the OTBR, I experienced that it is usually either:
    - The CoProcessor is configured as a NCP(by default) instead of a RCP. To build as a RCP, built with "-- -DOVERLAY_CONFIG="overlay-rcp.conf".
    - The baud rates of the OTBR is not the same as of the RCP. The OTBR Baud rate configuration is different based on if you use the direct version or the docker version. For the Docker version, you can set the baud rate by adding "?uart-baudrate=115200" after the port declaration in the docker run script. See our docs on OpenThread Border Router.
    The baud rate of the RCP is defined in the devicetree overlay files in the "boards" folder in your project folder, but I believe it should be 115200 by default.
    - The OTBR and RCP has the wrong Thread version. If your OTBR use Thread version 1.2, add CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y to your prj.conf. Thread 1.1 should be default.
    Does any/a combination of these help with your issue?
    Sigurd Hellesvik
  • In the nRF Connect SDK CoProcessor example I added the overlays: usb, rcp and logging.
    I added CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y to the prj.conf of the example
    And I've specified the baud rate in the Radio URL
    Output when not specifying the baud rate:
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: New relevant interface lo.IPv4 for mDNS.
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: Network interface enumeration completed.
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: Registering new address record for fe80::42:acff:fe11:3 on eth0.*.
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: Registering new address record for 172.17.0.3 on eth0.IPv4.
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: Registering new address record for ::1 on lo.*.
    Jan  3 15:16:29 5b76b697da3d avahi-daemon[188]: Registering new address record for 127.0.0.1 on lo.IPv4.
    Jan  3 15:16:29 5b76b697da3d rsyslogd: rsyslogd's groupid changed to 101
    Jan  3 15:16:29 5b76b697da3d rsyslogd: rsyslogd's userid changed to 101
    Jan  3 15:16:29 5b76b697da3d rsyslogd:  [origin software="rsyslogd" swVersion="8.32.0" x-pid="121" x-info="http://www.rsyslog.com"] start
    Jan  3 15:16:30 5b76b697da3d avahi-daemon[188]: Server startup complete. Host name is 5b76b697da3d.local. Local service cookie is 1699871024.
    Jan  3 15:16:30 5b76b697da3d otbr-agent[216]: [INFO]-UTILS---: Running 0.3.0-8ae81c5ac
    Jan  3 15:16:30 5b76b697da3d otbr-agent[216]: [INFO]-UTILS---: Thread version: 1.2.0
    Jan  3 15:16:30 5b76b697da3d otbr-agent[216]: [INFO]-UTILS---: Thread interface: wpan0
    Jan  3 15:16:30 5b76b697da3d otbr-agent[216]: [INFO]-UTILS---: Backbone interface: eth0
    Jan  3 15:16:30 5b76b697da3d otbr-agent[216]: [INFO]-UTILS---: Radio URL: spinel+hdlc+uart:///dev/ttyACM0
    Jan  3 15:16:30 5b76b697da3d otbr-web[244]: [INFO]-WEB-----: Running 0.3.0-8ae81c5ac
    Jan  3 15:16:30 5b76b697da3d otbr-web[244]: [INFO]-WEB-----: Border router web started on wpan0
    Jan  3 15:16:30 5b76b697da3d otbr-web[244]: [ERR ]-WEB-----: OpenThread daemon is not running.
    Jan  3 15:16:31 5b76b697da3d kernel: [ 5489.106173] usb 1-1.3: new full-speed USB device number 10 using dwc_otg
    Jan  3 15:16:31 5b76b697da3d kernel: [ 5489.248849] usb 1-1.3: New USB device found, idVendor=1915, idProduct=0000, bcdDevice= 2.06
    Jan  3 15:16:31 5b76b697da3d kernel: [ 5489.248876] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Jan  3 15:16:31 5b76b697da3d kernel: [ 5489.248891] usb 1-1.3: Product: Thread Co-Processor
    Jan  3 15:16:31 5b76b697da3d kernel: [ 5489.248920] usb 1-1.3: SerialNumber: 9DB0ECEDBB9858E8
    Jan  3 15:16:32 5b76b697da3d otbr-agent[216]: 49d.18:34:17.145 [CRIT]-PLAT----: HandleRcpTimeout() at ../../third_party/openthread/repo/src/lib/spinel/radio_spinel_impl.hpp:2218: RadioSpinelNoResponse
    And the output with baud rate 115200:
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: New relevant interface lo.IPv4 for mDNS.
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: Network interface enumeration completed.
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: Registering new address record for fe80::42:acff:fe11:3 on eth0.*.
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: Registering new address record for 172.17.0.3 on eth0.IPv4.
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: Registering new address record for ::1 on lo.*.
    Jan  3 15:18:25 c34eb76f0cb8 avahi-daemon[187]: Registering new address record for 127.0.0.1 on lo.IPv4.
    Jan  3 15:18:25 c34eb76f0cb8 rsyslogd: rsyslogd's groupid changed to 101
    Jan  3 15:18:25 c34eb76f0cb8 rsyslogd: rsyslogd's userid changed to 101
    Jan  3 15:18:25 c34eb76f0cb8 rsyslogd:  [origin software="rsyslogd" swVersion="8.32.0" x-pid="120" x-info="http://www.rsyslog.com"] start
    Jan  3 15:18:26 c34eb76f0cb8 otbr-agent[215]: [INFO]-UTILS---: Running 0.3.0-8ae81c5ac
    Jan  3 15:18:26 c34eb76f0cb8 otbr-agent[215]: [INFO]-UTILS---: Thread version: 1.2.0
    Jan  3 15:18:26 c34eb76f0cb8 otbr-agent[215]: [INFO]-UTILS---: Thread interface: wpan0
    Jan  3 15:18:26 c34eb76f0cb8 otbr-agent[215]: [INFO]-UTILS---: Backbone interface: eth0
    Jan  3 15:18:26 c34eb76f0cb8 otbr-agent[215]: [INFO]-UTILS---: Radio URL: spinel+hdlc+uart:///dev/ttyACM0?uart-baudrate=115200
    Jan  3 15:18:26 c34eb76f0cb8 avahi-daemon[187]: Server startup complete. Host name is c34eb76f0cb8.local. Local service cookie is 812342254.
    Jan  3 15:18:26 c34eb76f0cb8 otbr-web[243]: [INFO]-WEB-----: Running 0.3.0-8ae81c5ac
    Jan  3 15:18:26 c34eb76f0cb8 otbr-web[243]: [INFO]-WEB-----: Border router web started on wpan0
    Jan  3 15:18:26 c34eb76f0cb8 otbr-web[243]: [ERR ]-WEB-----: OpenThread daemon is not running.
    Jan  3 15:18:28 c34eb76f0cb8 otbr-agent[215]: 49d.18:36:13.098 [CRIT]-PLAT----: HandleRcpTimeout() at ../../third_party/openthread/repo/src/lib/spinel/radio_spinel_impl.hpp:2218: RadioSpinelNoResponse
  • That doesn't help, I am getting the message:
    "ERROR: No debuggers were discovered."
    It does not behave as it used to anymore.
  • It seems there could be a problem with the debugger chip on the nRF21540dk.
    Try to update the firmware of the debugger by drag-and-drop the J-link/Interface MCU firmware to the BOOTLOADER drive. It can be downloaded here: https://www.nordicsemi.com/Products/Development-hardware/nRF52840-DK/Download?lang=en#infotabs.
    Sigurd Hellesvik
  • My nrf21540DK is working again, thanks to the firmware you mentioned. how strange. I've never had this happen to a DK before.
    Now I am back at the same spot as before.
    Coprocessor with nRFConnect SDK 1.7.1 results in an error:
    "RCP is missing required capabilities: tx-security tx-timing"
    pi@raspberrypi:~ $ sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" --volume /dev/:/dev/ nrfconnect/otbr:e149a60 --radio-url spinel+hdlc+uart:///dev/serial/by-id/usb-Nordic_Semiconductor_ASA_Thread_Co-Processor_9DB0ECEDBB9858E8-if00?uart-reset
    RADIO_URL: spinel+hdlc+uart:///dev/serial/by-id/usb-Nordic_Semiconductor_ASA_Thread_Co-Processor_9DB0ECEDBB9858E8-if00?uart-reset
    TUN_INTERFACE_NAME: wpan0
    BACKBONE_INTERFACE: eth0
    NAT64_PREFIX: 64:ff9b::/96
    AUTO_PREFIX_ROUTE: true
    AUTO_PREFIX_SLAAC: true
    +++ dirname /app/script/server
    ++ cd /app/script/..
    ++ [[ ! -n x ]]
    ++ echo 'Current platform is ubuntu'
    ++ with BORDER_ROUTING
    ++ local value
    +++ printenv BORDER_ROUTING
    ++ value=1
    ++ [[ -z 1 ]]
    ++ [[ 1 == 1 ]]
    ++ with DHCPV6_PD
    ++ local value
    +++ printenv DHCPV6_PD
    ++ value=
    ++ [[ -z '' ]]
    ++ [[ -f examples/platforms/ubuntu/default ]]
    ++ [[ '' == 1 ]]
    ++ local value
    ++ value=1
    ++ [[ -z 1 ]]
    ++ [[ 1 == 1 ]]
    ++ with NETWORK_MANAGER
    ++ local value
    +++ printenv NETWORK_MANAGER
    ++ value=
    ++ [[ -z '' ]]
    ++ [[ '' == 1 ]]
    ++ STAGE_DIR=/app/stage
    ++ BUILD_DIR=/app/build
    ++ [[ -d /app/stage ]]
    ++ mkdir -v -p /app/stage
    mkdir: created directory '/app/stage'
    ++ [[ -d /app/build ]]
    ++ mkdir -v -p /app/build
    mkdir: created directory '/app/build'
    ++ export PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    ++ PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    +++ basename /app/script/server
    ++ TASKNAME=server
    ++ BEFORE_HOOK=examples/platforms/ubuntu/before_server
    ++ AFTER_HOOK=examples/platforms/ubuntu/after_server
    ++ [[ ! -f examples/platforms/ubuntu/before_server ]]
    ++ BEFORE_HOOK=/dev/null
    ++ [[ ! -f examples/platforms/ubuntu/after_server ]]
    ++ AFTER_HOOK=/dev/null
    + . script/_nat64
    ++ TAYGA_DEFAULT=/etc/default/tayga
    ++ TAYGA_CONF=/etc/tayga.conf
    ++ TAYGA_IPV4_ADDR=192.168.255.1
    ++ TAYGA_IPV6_ADDR=fdaa:bb:1::1
    ++ TAYGA_TUN_V6_ADDR=fdaa:bb:1::2
    ++ NAT44_SERVICE=/etc/init.d/otbr-nat44
    ++ WLAN_IFNAMES=eth0
    + . script/_dns64
    ++ BIND_CONF_OPTIONS=/etc/bind/named.conf.options
    ++ NAT64_PREFIX=64:ff9b::/96
    ++ DNS64_NAMESERVER_ADDR=127.0.0.1
    +++ echo 64:ff9b::/96
    +++ tr '"/"' '"/"'
    ++ DNS64_CONF='dns64 64:ff9b::/96 { clients { thread; }; recursive-only yes; };'
    ++ without NAT64
    ++ with NAT64
    ++ local value
    +++ printenv NAT64
    ++ value=1
    ++ [[ -z 1 ]]
    ++ [[ 1 == 1 ]]
    ++ test ubuntu = ubuntu
    ++ '[' ubuntu = raspbian ']'
    ++ '[' ubuntu = beagleboneblack ']'
    ++ '[' ubuntu = ubuntu ']'
    ++ RESOLV_CONF_HEAD=/etc/resolvconf/resolv.conf.d/head
    + main
    + . /dev/null
    + sudo sysctl --system
    * Applying /etc/sysctl.d/10-console-messages.conf ...
    kernel.printk = 4 4 1 7
    * Applying /etc/sysctl.d/10-ipv6-privacy.conf ...
    net.ipv6.conf.all.use_tempaddr = 2
    net.ipv6.conf.default.use_tempaddr = 2
    * Applying /etc/sysctl.d/10-kernel-hardening.conf ...
    kernel.kptr_restrict = 1
    * Applying /etc/sysctl.d/10-link-restrictions.conf ...
    fs.protected_hardlinks = 1
    fs.protected_symlinks = 1
    * Applying /etc/sysctl.d/10-magic-sysrq.conf ...
    kernel.sysrq = 176
    * Applying /etc/sysctl.d/10-network-security.conf ...
    net.ipv4.conf.default.rp_filter = 1
    net.ipv4.conf.all.rp_filter = 1
    net.ipv4.tcp_syncookies = 1
    * Applying /etc/sysctl.d/10-ptrace.conf ...
    * Applying /etc/sysctl.d/10-zeropage.conf ...
    vm.mmap_min_addr = 32768
    * Applying /etc/sysctl.d/60-otbr-accept-ra.conf ...
    net.ipv6.conf.eth0.accept_ra = 2
    net.ipv6.conf.eth0.accept_ra_rt_info_max_plen = 64
    * Applying /etc/sysctl.d/60-otbr-ip-forward.conf ...
    net.ipv6.conf.all.forwarding = 1
    net.ipv4.ip_forward = 1
    * Applying /etc/sysctl.conf ...
    + nat64_start
    + with NAT64
    + local value
    ++ printenv NAT64
    + value=1
    + [[ -z 1 ]]
    + [[ 1 == 1 ]]
    + with DOCKER
    + local value
    ++ printenv DOCKER
    + value=1
    + [[ -z 1 ]]
    + [[ 1 == 1 ]]
     * Starting userspace NAT64 tayga                                                              [ OK ]
    + dns64_start
    + with NAT64
    + local value
    ++ printenv NAT64
    + value=1
    + [[ -z 1 ]]
    + [[ 1 == 1 ]]
    + with DNS64
    + local value
    ++ printenv DNS64
    + value=1
    + [[ -z 1 ]]
    + [[ 1 == 1 ]]
    ++ dpkg -L bind9
    ++ cut -d/ -f4
    + have systemctl
    /usr/sbin/service
     * Starting domain name service... bind9                                                       [ OK ]
    + have systemctl
    + have service
     * Starting enhanced syslogd rsyslogd                                                          [ OK ]
     * Starting system message bus dbus                                                            [ OK ]
     * Starting Avahi mDNS/DNS-SD Daemon avahi-daemon                                              [ OK ]
     * Starting thread border agent otbr-agent                                                     [ OK ]
    + without WEB_GUI
    + with WEB_GUI
    + local value
    ++ printenv WEB_GUI
    + value=1
    + [[ -z 1 ]]
    + [[ 1 == 1 ]]
     * Starting thread web interface otbr-web                                                      [ OK ]
    + . /dev/null
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: New relevant interface lo.IPv4 for mDNS.
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: Network interface enumeration completed.
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: Registering new address record for fd11:db8:1::2 on eth0.*.
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: Registering new address record for 172.19.0.2 on eth0.IPv4.
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: Registering new address record for ::1 on lo.*.
    Jan 11 12:00:07 890599ffee8e avahi-daemon[185]: Registering new address record for 127.0.0.1 on lo.IPv4.
    Jan 11 12:00:08 890599ffee8e rsyslogd: rsyslogd's groupid changed to 101
    Jan 11 12:00:08 890599ffee8e rsyslogd: rsyslogd's userid changed to 101
    Jan 11 12:00:08 890599ffee8e rsyslogd:  [origin software="rsyslogd" swVersion="8.32.0" x-pid="118" x-info="http://www.rsyslog.com"] start
    Jan 11 12:00:08 890599ffee8e avahi-daemon[185]: Server startup complete. Host name is 890599ffee8e.local. Local service cookie is 2733238354.
    Jan 11 12:00:08 890599ffee8e otbr-agent[213]: [INFO]-UTILS---: Running 0.3.0-e149a60eb
    Jan 11 12:00:08 890599ffee8e otbr-agent[213]: [INFO]-UTILS---: Thread version: 1.2.0
    Jan 11 12:00:08 890599ffee8e otbr-agent[213]: [INFO]-UTILS---: Thread interface: wpan0
    Jan 11 12:00:08 890599ffee8e otbr-agent[213]: [INFO]-UTILS---: Backbone interface: eth0
    Jan 11 12:00:08 890599ffee8e otbr-agent[213]: [INFO]-UTILS---: Radio URL: spinel+hdlc+uart:///dev/serial/by-id/usb-Nordic_Semiconductor_ASA_Thread_Co-Processor_9DB0ECEDBB9858E8-if00?uart-reset
    Jan 11 12:00:09 890599ffee8e otbr-web[241]: [INFO]-WEB-----: Running 0.3.0-e149a60eb
    Jan 11 12:00:09 890599ffee8e otbr-web[241]: [INFO]-WEB-----: Border router web started on wpan0
    Jan 11 12:00:09 890599ffee8e otbr-web[241]: [ERR ]-WEB-----: OpenThread daemon is not running.
    Jan 11 12:00:10 890599ffee8e kernel: [ 2668.136910] usb 1-1.2: Manufacturer: Nordic Semiconductor ASA
    Jan 11 12:00:10 890599ffee8e kernel: [ 2668.139588] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
    Jan 11 12:00:10 890599ffee8e mtp-probe: checking bus 1, device 15: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
    Jan 11 12:00:10 890599ffee8e mtp-probe: bus: 1, device: 15 was not an MTP device
    Jan 11 12:00:11 890599ffee8e otbr-agent[213]: [INFO]-PLAT----: RCP reset: RESET_POWER_ON
    Jan 11 12:00:11 890599ffee8e otbr-agent[213]: [NOTE]-PLAT----: RCP API Version: 4
    Jan 11 12:00:11 890599ffee8e otbr-agent[213]: [CRIT]-PLAT----: RCP is missing required capabilities: tx-security tx-timing
    Jan 11 12:00:11 890599ffee8e otbr-agent[213]: [CRIT]-PLAT----: CheckRadioCapabilities() at ../../third_party/openthread/repo/src/lib/spinel/radio_spinel_impl.hpp:382: RadioSpinelIncompatible
    Coprocessor with nRFConnect SDK 1.8.1 does not present a /dev/ttyACM0 device. RTT output is fine, USB is just not presented to the RPi (nothing in dmesg).
  • Hi
    The ""RCP is missing required capabilities: tx-security tx-timing"" sounds like you have Thread version 1.1 instead of 1.2 for the RCP.
    Did you build with the following command?
    west build -p always -b nrf52840dk_nrf52840 nrf/samples/openthread/coprocessor/ -- -DOVERLAY_CONFIG="overlay-rcp.conf ../cli/overlay-thread_1_2.conf"
    It is weird that the v1.8.0 does not show up on devices.
    Are you sue that it does not simply choose another ACM? "ls /det/ttyACM*"
    Which of the two USB connectors on thenRF52840DK have you connected?
    Sigurd Hellesvik
  • ** Edit ** After a pristine build I got it running. I will now check if the signal strength is as it should be
    I specified "CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y" in the prj.conf
    My build output:
    > Executing task: nRF Connect: Build coprocessor171/build (active) <
    Building coprocessor171
    west build --build-dir d:\IoT\coprocessor171\build d:\IoT\coprocessor171 --pristine --board nrf21540dk_nrf52840 -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="d:/IoT/coprocessor171" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DDTC_OVERLAY_FILE:STRING="d:/IoT/coprocessor171/boards/nrf21540dk_nrf52840.overlay" -DCONF_FILE:STRING="d:/IoT/coprocessor171/prj.conf" -DOVERLAY_CONFIG:STRING="d:/IoT/coprocessor171/overlay-usb.conf;d:/IoT/coprocessor171/overlay-rcp.conf;d:/IoT/coprocessor171/overlay-logging.conf"
    Including boilerplate (Zephyr base): D:/IoT/nRFConnectSDK/v1.7.1/zephyr/cmake/app/boilerplate.cmake
    -- Application: D:/IoT/coprocessor171
    -- Zephyr version: 2.6.99 (D:/IoT/nRFConnectSDK/v1.7.1/zephyr), build: v2.6.99-ncs1-1
    -- Found Python3: D:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
    -- Board: nrf21540dk_nrf52840
    -- Cache files will be written to: D:/IoT/nRFConnectSDK/v1.7.1/zephyr/.cache
    -- Found dtc: D:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (d:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt)
    -- Found BOARD.dts: D:/IoT/nRFConnectSDK/v1.7.1/zephyr/boards/arm/nrf21540dk_nrf52840/nrf21540dk_nrf52840.dts
    -- Found devicetree overlay: d:/IoT/coprocessor171/boards/nrf21540dk_nrf52840.overlay
    -- Generated zephyr.dts: D:/IoT/coprocessor171/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: D:/IoT/coprocessor171/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: D:/IoT/coprocessor171/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: D:/IoT/coprocessor171/build/zephyr/dts.cmake
    Parsing D:/IoT/coprocessor171/Kconfig
    Loaded configuration 'D:/IoT/nRFConnectSDK/v1.7.1/zephyr/boards/arm/nrf21540dk_nrf52840/nrf21540dk_nrf52840_defconfig'
    Merged configuration 'd:/IoT/coprocessor171/prj.conf'
    Merged configuration '../common/overlay-ot-defaults.conf'
    Merged configuration 'd:/IoT/coprocessor171/overlay-usb.conf'
    Merged configuration 'd:/IoT/coprocessor171/overlay-rcp.conf'
    Merged configuration 'd:/IoT/coprocessor171/overlay-logging.conf'
    Merged configuration 'D:/IoT/coprocessor171/build/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'D:/IoT/coprocessor171/build/zephyr/.config'
    Kconfig header saved to 'D:/IoT/coprocessor171/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: D:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
    -- OpenThread Source Directory: D:/IoT/nRFConnectSDK/v1.7.1/modules/lib/openthread
    -- Check if the system is big endian
    -- Searching 16 bit integer
    -- Looking for sys/types.h
    -- Looking for sys/types.h - found
    -- Looking for stdint.h
    -- Looking for stdint.h - found
    -- Looking for stddef.h
    -- Looking for stddef.h - found
    -- Check size of unsigned short
    -- Check size of unsigned short - done
    -- Searching 16 bit integer - Using unsigned short
    -- Check if the system is big endian - little endian
    -- Package Name: OPENTHREAD
    -- Setting default package version: v1.7.0
    -- Package Version: v1.7.0
    CMake Warning (dev) at D:\IoT\nRFConnectSDK\v1.7.1\nrfxlib\nrf_security\cmake\extensions.cmake:652:
      Syntax Warning in cmake code at column 32
      Argument not separated from preceding token by whitespace.
      D:\IoT\nRFConnectSDK\v1.7.1\nrfxlib\nrf_security\CMakeLists.txt:185 (include)
    This warning is for project developers.  Use -Wno-dev to suppress it.
    CMake Warning at D:\IoT\nRFConnectSDK\v1.7.1\zephyr\CMakeLists.txt:1612 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/IoT/coprocessor171/build
    [1/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/arc4.c.obj
    [2/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/aesni.c.obj
    [3/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/blowfish.c.obj
    [4/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/des.c.obj
    [5/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/aria.c.obj
    [6/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/camellia.c.obj
    [7/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/error.c.obj
    [8/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/base64.c.obj
    [9/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/gcm.c.obj
    [10/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/asn1write.c.obj
    [11/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/asn1parse.c.obj
    [12/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ctr_drbg.c.obj
    [13/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/cipher_wrap.c.obj
    [14/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md2.c.obj
    [15/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/entropy_poll.c.obj
    [16/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/cipher.c.obj
    [17/398] Generating objects/cc3xx.mon
    [18/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/debug.c.obj
    [19/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/havege.c.obj
    [20/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/entropy.c.obj
    [21/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/hkdf.c.obj
    [22/398] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [23/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/nist_kw.c.obj
    [24/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md4.c.obj
    [25/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/hmac_drbg.c.obj
    [26/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/padlock.c.obj
    [27/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkcs12.c.obj
    [28/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md5.c.obj
    [29/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md.c.obj
    [30/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkcs5.c.obj
    [31/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ripemd160.c.obj
    [32/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pk.c.obj
    [33/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/timing.c.obj
    [34/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pk_wrap.c.obj
    [35/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/platform.c.obj
    [36/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/oid.c.obj
    [37/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkparse.c.obj
    [38/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/platform_util.c.obj
    [39/398] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [40/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/version_features.c.obj
    [41/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/xtea.c.obj
    [42/398] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [43/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_client.c.obj
    [44/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/bignum.c.obj
    [45/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto.c.obj
    [46/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkwrite.c.obj
    [47/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_rsa.c.obj
    [48/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/version.c.obj
    [49/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_slot_management.c.obj
    [50/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_ecp.c.obj
    [51/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_storage.c.obj
    [52/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkcs11.c.obj
    [53/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/certs.c.obj
    [54/398] Generating include/generated/driver-validation.h
    [55/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_create.c.obj
    [56/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_driver_wrappers.c.obj
    [57/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/replacements/pem.c.obj
    [58/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/utils/lookup_table.cpp.obj
    [59/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/error_api.cpp.obj
    [60/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509.c.obj
    [61/398] Building CXX object modules/openthread/build/src/lib/hdlc/CMakeFiles/openthread-hdlc.dir/hdlc.cpp.obj
    [62/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/error.cpp.obj
    [63/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/utils/parse_cmdline.cpp.obj
    [64/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/thread/link_quality.cpp.obj
    [65/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/random_noncrypto_api.cpp.obj
    [66/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/instance_api.cpp.obj
    [67/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/logging_api.cpp.obj
    [68/398] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [69/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/tasklet_api.cpp.obj
    [70/398] Linking CXX static library modules\openthread\build\src\lib\hdlc\libopenthread-hdlc.a
    [71/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/tasklet.cpp.obj
    [72/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/diags_api.cpp.obj
    [73/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/link_raw_api.cpp.obj
    [74/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/instance.cpp.obj
    [75/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/crypto/aes_ecb.cpp.obj
    [76/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/random_manager.cpp.obj
    [77/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/logging.cpp.obj
    [78/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/string.cpp.obj
    [79/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/crypto/aes_ccm.cpp.obj
    [80/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/radio/radio_callbacks.cpp.obj
    [81/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/sub_mac_callbacks.cpp.obj
    [82/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/mac_types.cpp.obj
    [83/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/diags/factory_diags.cpp.obj
    [84/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/timer.cpp.obj
    [85/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/radio/radio_platform.cpp.obj
    [86/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/link_raw.cpp.obj
    [87/398] Building CXX object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel_encoder.cpp.obj
    [88/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/radio/radio.cpp.obj
    [89/398] Building CXX object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel_buffer.cpp.obj
    [90/398] Building CXX object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel_decoder.cpp.obj
    [91/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/mac_frame.cpp.obj
    [92/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/changed_props_set.cpp.obj
    [93/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509write_csr.c.obj
    [94/398] Building C object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel.c.obj
    [95/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/sub_mac.cpp.obj
    [96/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_cache.c.obj
    [97/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_csr.c.obj
    [98/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_base_dispatcher.cpp.obj
    [99/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_crl.c.obj
    [100/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/net_sockets.c.obj
    [101/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/platform.c.obj
    [102/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_spi.cpp.obj
    [103/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_ticket.c.obj
    [104/398] Linking CXX static library modules\openthread\build\src\lib\spinel\libopenthread-spinel-rcp.a
    [105/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_base_radio.cpp.obj
    [106/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_hdlc.cpp.obj
    [107/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_cookie.c.obj
    [108/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/replacements/ssl_ciphersuites.c.obj
    [109/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/cc310/CMakeFiles/mbedcrypto_cc3xx_noglue.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ecjpake.c.obj
    [110/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_base.cpp.obj
    [111/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_crt.c.obj
    [112/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_cli.c.obj
    [113/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_srv.c.obj
    [114/398] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
    [115/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_msg.c.obj
    [116/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_tls.c.obj
    [117/398] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\mbedtls\libmbedx509.a
    [118/398] cmd.exe /C "cd /D D:\IoT\coprocessor171\build\modules\openthread\build && D:\IoT\nRFConnectSDK\v1.7.1\toolchain\opt\bin\cmake.exe -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1;OPENTHREAD_CONFIG_DIAG_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1;OPENTHREAD_CONFIG_JOINER_ENABLE=1;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_2;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=2;BUILD_VERSION=v2.6.99-ncs1-1;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=0;__PROGRAM_START;NRF52840_XXAA;NRF_802154_ECB_PRIORITY=0;NRF_802154_SWI_PRIORITY=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=16;NRF_802154_PENDING_EXTENDED_ADDRESSES=16;NRF_802154_RX_BUFFERS=16;NRF_802154_CCA_CORR_LIMIT_DEFAULT=2;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45;NRF_802154_CSMA_CA_ENABLED=1;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;PSA_CRYPTO_SECURE;MBEDTLS_CONFIG_FILE="nrf-config.h"" -P D:/IoT/nRFConnectSDK/v1.7.1/modules/lib/openthread/etc/cmake/print.cmake"
    PACKAGE_NAME=OPENTHREAD
    KERNEL
    __ZEPHYR__=1
    _FORTIFY_SOURCE=2
    __PROGRAM_START
    NRF52840_XXAA
    PSA_CRYPTO_SECURE
    MBEDTLS_CONFIG_FILE=nrf-config.h
    [119/398] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\mbedtls\libmbedtls.a
    [120/398] Linking CXX static library modules\openthread\build\src\core\libopenthread-radio.a
    [121/398] Linking CXX static library modules\openthread\build\src\ncp\libopenthread-rcp.a
    [122/398] Generating include/generated/offsets.h
    [123/398] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [124/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [125/398] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [126/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [127/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
    [128/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [129/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [130/398] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [131/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
    [132/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [133/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [134/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [135/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
    [136/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init_array.c.obj
    [137/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [138/398] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [139/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [140/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_ctors.c.obj
    [141/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_dtors.c.obj
    [142/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [143/398] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_vtable.cpp.obj
    [144/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_virtual.c.obj
    [145/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [146/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_rtt.c.obj
    [147/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [148/398] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_new.cpp.obj
    [149/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [150/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_work_q.c.obj
    [151/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [152/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [153/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [154/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
    [155/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [156/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
    [157/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_transfer.c.obj
    [158/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [159/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [160/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_descriptor.c.obj
    [161/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [162/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [163/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
    [164/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
    [165/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/class/cdc_acm.c.obj
    [166/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
    [167/398] Building C object zephyr/CMakeFiles/zephyr.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [168/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
    [169/398] Generating linker_zephyr_prebuilt.cmd
    [170/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
    [171/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/hwinfo/hwinfo_weak_impl.c.obj
    [172/398] Building C object zephyr/CMakeFiles/zephyr.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [173/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/__aeabi_atexit.c.obj
    [174/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
    [175/398] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [176/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [177/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [178/398] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
    [179/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/hwinfo/hwinfo_nrf.c.obj
    [180/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_device.c.obj
    [181/398] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [182/398] Building C object CMakeFiles/app.dir/src/main.c.obj
    [183/398] Building C object modules/nrf/drivers/mpsl/temp_nrf5/CMakeFiles/..__nrf__drivers__mpsl__temp_nrf5.dir/temp_nrf5_mpsl.c.obj
    [184/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [185/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [186/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [187/398] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
    [188/398] Building C object CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj
    [189/398] Linking CXX static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
    [190/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [191/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [192/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [193/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/ieee802154/ieee802154_nrf5.c.obj
    [194/398] Linking CXX static library modules\nrf\drivers\mpsl\flash_sync\lib..__nrf__drivers__mpsl__flash_sync.a
    [195/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [196/398] Linking CXX static library modules\nrf\drivers\mpsl\temp_nrf5\lib..__nrf__drivers__mpsl__temp_nrf5.a
    [197/398] Linking CXX static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    [198/398] Linking CXX static library app\libapp.a
    [199/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [200/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [201/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [202/398] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [203/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [204/398] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [205/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [206/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [207/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [208/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [209/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [210/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [211/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [212/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/usb/device/usb_dc_nrfx.c.obj
    [213/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [214/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [215/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [216/398] Linking CXX static library zephyr\arch\common\libisr_tables.a
    [217/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [218/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [219/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [220/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [221/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [222/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [223/398] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [224/398] Linking CXX static library zephyr\arch\common\libarch__common.a
    [225/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [226/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [227/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [228/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [229/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [230/398] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [231/398] Linking CXX static library zephyr\libzephyr.a
    [232/398] Linking CXX static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [233/398] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [234/398] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [235/398] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [236/398] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [237/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [238/398] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [239/398] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [240/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [241/398] Linking CXX static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [242/398] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
    [243/398] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [244/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [245/398] Linking CXX static library zephyr\lib\posix\liblib__posix.a
    [246/398] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [247/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj
    [248/398] Building C object zephyr/subsys/net/l2/openthread/CMakeFiles/subsys__net__ip__l2__openthread.dir/openthread_utils.c.obj
    [249/398] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [250/398] Linking CXX static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
    [251/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv6.c.obj
    [252/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_stats.c.obj
    [253/398] Building C object zephyr/subsys/net/l2/openthread/CMakeFiles/subsys__net__ip__l2__openthread.dir/openthread.c.obj
    [254/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_mgmt.c.obj
    [255/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6_nbr.c.obj
    [256/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/nbr.c.obj
    [257/398] Linking CXX static library zephyr\subsys\net\libsubsys__net.a
    [258/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/udp.c.obj
    [259/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj
    [260/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj
    [261/398] Building C object zephyr/subsys/net/lib/conn_mgr/CMakeFiles/subsys__net__lib__conn_mgr.dir/events_handler.c.obj
    [262/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/misc.c.obj
    [263/398] Linking CXX static library zephyr\subsys\net\l2\openthread\libsubsys__net__ip__l2__openthread.a
    [264/398] Building C object zephyr/subsys/net/lib/conn_mgr/CMakeFiles/subsys__net__lib__conn_mgr.dir/conn_mgr.c.obj
    [265/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/entropy.c.obj
    [266/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6.c.obj
    [267/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/alarm.c.obj
    [268/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/memory.c.obj
    [269/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/platform.c.obj
    [270/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/spi.c.obj
    [271/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj
    [272/398] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/__/__/misc/empty_file.c.obj
    [273/398] Linking CXX static library zephyr\subsys\net\lib\conn_mgr\libsubsys__net__lib__conn_mgr.a
    [274/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/diag.c.obj
    [275/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/settings.c.obj
    [276/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/logging.c.obj
    [277/398] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [278/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [279/398] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [280/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/radio.c.obj
    [281/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/uart.c.obj
    [282/398] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [283/398] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [284/398] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrf/drivers/entropy/entropy_cc310.c.obj
    [285/398] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [286/398] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [287/398] Linking CXX static library zephyr\subsys\random\libsubsys__random.a
    [288/398] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [289/398] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [290/398] Linking CXX static library zephyr\subsys\net\ip\libsubsys__net__ip.a
    [291/398] Linking CXX static library zephyr\subsys\net\lib\openthread\platform\libopenthread_platform.a
    [292/398] Linking CXX static library zephyr\drivers\flash\libdrivers__flash.a
    [293/398] Linking CXX static library zephyr\drivers\gpio\libdrivers__gpio.a
    [294/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_irq_zephyr.c.obj
    [295/398] Building C object modules/nrf/subsys/ieee802154/CMakeFiles/..__nrf__subsys__ieee802154.dir/nrf_802154_configurator.c.obj
    [296/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/radio/platform/nrf_802154_random_zephyr.c.obj
    [297/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_crit_sect.c.obj
    [298/398] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [299/398] Linking CXX static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
    [300/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_clock_zephyr.c.obj
    [301/398] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/mpsl_fem.c.obj
    [302/398] Linking CXX static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [303/398] Linking CXX static library zephyr\drivers\entropy\libdrivers__entropy.a
    [304/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_zephyr.c.obj
    [305/398] Linking CXX static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
    [306/398] Linking CXX static library modules\nrf\subsys\ieee802154\lib..__nrf__subsys__ieee802154.a
    [307/398] Linking CXX static library zephyr\drivers\serial\libdrivers__serial.a
    [308/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/nrf_802154/sl/platform/lp_timer/nrf_802154_lp_timer.c.obj
    [309/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
    [310/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/nrf_802154/sl/platform/hp_timer/nrf_802154_hp_timer.c.obj
    [311/398] Linking CXX static library modules\nrf\subsys\mpsl\fem\lib..__nrf__subsys__mpsl__fem.a
    [312/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_systick.c.obj
    [313/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_temperature_zephyr.c.obj
    [314/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [315/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [316/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [317/398] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [318/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/__/mbedtls/replacements/memory_buffer_alloc.c.obj
    [319/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/__/mbedtls/mbedtls_heap.c.obj
    [320/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug.c.obj
    [321/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [322/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_queue.c.obj
    [323/398] Linking CXX static library modules\hal_nordic\nrf_802154\libnrf-802154-platform.a
    [324/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154.c.obj
    [325/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core_hooks.c.obj
    [326/398] Linking CXX static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
    [327/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rx_buffer.c.obj
    [328/398] Building C object modules/segger/CMakeFiles/modules__segger.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [329/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug_assert.c.obj
    [330/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_aes_ccm.c.obj
    [331/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_critical_section.c.obj
    [332/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_peripherals_alloc.c.obj
    [333/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_pib.c.obj
    [334/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [335/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rssi.c.obj
    [336/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_encrypt.c.obj
    [337/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_dppi.c.obj
    [338/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_swi.c.obj
    [339/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_stats.c.obj
    [340/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_tx_work_buffer.c.obj
    [341/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_ppi.c.obj
    [342/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core.c.obj
    [343/398] Linking CXX static library modules\segger\libmodules__segger.a
    [344/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_csma_ca.c.obj
    [345/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ie_writer.c.obj
    [346/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_frame_parser.c.obj
    [347/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_filter.c.obj
    [348/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ifs.c.obj
    [349/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_generator.c.obj
    [350/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_pib_ram.c.obj
    [351/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_delayed_trx.c.obj
    [352/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_data.c.obj
    [353/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_writer.c.obj
    [354/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_usbd.c.obj
    [355/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_priority_drop_swi.c.obj
    [356/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_precise_ack_timeout.c.obj
    [357/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_imm_ack_generator.c.obj
    [358/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_notification_swi.c.obj
    [359/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx.c.obj
    [360/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [361/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [362/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_enh_ack_generator.c.obj
    [363/398] Linking CXX static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [364/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [365/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [366/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [367/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_request_swi.c.obj
    [368/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [369/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [370/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [371/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [372/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [373/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [374/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [375/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [376/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [377/398] Linking CXX static library modules\nrfxlib\nrf_802154\nrf_802154\driver\libnrf-802154-driver.a
    [378/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [379/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [380/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [381/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [382/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [383/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [384/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [385/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [386/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [387/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [388/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [389/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [390/398] Linking CXX static library zephyr\kernel\libkernel.a
    [391/398] Linking CXX executable zephyr\zephyr_prebuilt.elf
    [392/398] Generating linker.cmd
    [393/398] Generating isr_tables.c, isrList.bin
    [394/398] Generating dev_handles.c
    [395/398] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [396/398] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [397/398] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [398/398] Linking CXX executable zephyr\zephyr.elf
               FLASH:      216520 B         1 MB     20.65%
                SRAM:       80488 B       256 KB     30.70%
            IDT_LIST:          0 GB         2 KB      0.00%
    Terminal will be reused by tasks, press any key to close it.
    No, I build using VSCode. I have never built using west directly before. Can I just run this from the project base directory?
    I connect the debugger to my PC for programming, and connect the "nRF USB" to the RPi. This is the same in both projects (1.7.1 and 1.8.0). in the CoProcessor 1.7.1 I do get /dev/ttyACM0, but not in 1.8.0
    My build output:
    -- Configuring done
    -- Generating done
    KERNEL
    __ZEPHYR__=1
    _FORTIFY_SOURCE=2
    __PROGRAM_START
    NRF52840_XXAA
    PSA_CRYPTO_SECURE
