Hard Fault using TWI_SCANNER example
Trying to run the TWI_SCANNER example on a pca10100 hard faults. The .emProject file has been modified per the instructions at https://devzone.nordicsemi.com/f/nordic-q-a/57816/ble_app_beacon-not-available-for-pca10100/234466#234466
The fault is consistently at this location:
The registers are as follows at this point in the code:
Code is as follows:
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID     0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
 #define TWI_ADDRESSES      127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = 26,
       .sda                = 27,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, app_error_handler_bare, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint8_t address;
    uint8_t sample_data;
    bool detected_device = false;
    NRF_LOG_INFO("TWI scanner started.");
    NRF_LOG_FLUSH();
    twi_init();
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
        NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.");
        NRF_LOG_FLUSH();
    //while (true)
    //    NRF_LOG_INFO("No device was found.");
However, even removing all of the code (i.e. leaving void main(void){} completely empty except for an empty while loop) results in the exact same hard fault. I get no build errors, and the code deploys without error or fault via J-Link.
Would appreciate some guidance.
Best,
S.
    Try running the example as-is, without returning from the main() function.
    nRF5 SDK is bare metal, so you shouldn't return from main() in that case.
    Håkon
  • Hi Håkon,
    Thanks so much for the reply.
    The issue was in trying to use the pca10056 solution; I got no hard faults when I switch to the 10040 solution and run the same code.
    However, I now detect a valid TWI device at 0x00 - this is strange, as I was expecting a device between 0x08 and 0x77.
    Note: this happens when I switch pins - I actually have two i2c devices, but am only reading one at a time right now.
    Is this device address valid?
    Lastly, I'm relying on the nrf52833's internal pullups to set the signals high. It looks like this is happening by default - can you confirm?
    Best wishes and thanks,
    S.
  • To clarify the language "This happens when I switch pins", what I mean is I get the same address (0x00) even when I manually change the SCL and SDA pins to address two different devices.
    Example:
    Device 1) SCL:P0.21, SDA:P0.20 - in this instance I expect an address between 0x2a or 0x2b
    Device 2) SCL:P0.26, SDA:P0.27 - in this instance I expect one of six addresses, none of them are 0x00
    Yet, both return the same address (0x00) when I run the code.
    you should start scanning from address=1.
    Example:
    Have you scoped the lines to see what happens?
    Did you remove the pca10056 system files and add system_nrf52833 and nrf52833-startup files?
    Yes, nrfx_twim.c enables pull-ups in the pad.
    Håkon
