we have high current consumption when we are using Accelerometer lis3dh with SPI with no transfer at all on SPI
- We have 2 SPI’s in the circuit. The first SPI is connecting to serial Flash. It consumes almost nothing when there is no transfer.
- When we connect the accelerometer to the CPU in I2C, it consume low power (110uA) – This current is consumed between transferred ( 30uA “leakage current” + 400hz acc sample rate)
- When we connect SPI to the accelerometer, it consume 800uA without any transfer.
The following code show the problem. No transfer is done on the accelerometer at
init_acc_spi(spim_handler);
uninit_acc_spix();
static void init_acc_spi(nrfx_spim_evt_handler_t handler)
nrfx_err_t err_code;
nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
// spi_config.frequency = NRF_SPI_FREQ_4M; (default rate)
spi_config.frequency = NRF_SPI_FREQ_8M;
spi_config.sck_pin = HAL_SPI2_CLK;
spi_config.ss_pin = HAL_SPI2_SS;
spi_config.mosi_pin = HAL_SPI2_MOSI;
spi_config.miso_pin = HAL_SPI2_MISO;
spi_config.mode = NRF_SPI_MODE_0;
err_code = nrfx_spim_init(&m_spim2, &spi_config, handler, NULL);
if (NRFX_SUCCESS != err_code)
NRFX_LOG_ERROR("%s nrfx_spim_init failed: %s", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
static void uninit_acc_spix(void)
nrfx_spim_uninit(&m_spim2);
nrf_gpio_cfg_default(HAL_SPI2_CLK);
nrf_gpio_cfg_default(HAL_SPI2_SS);
nrf_gpio_cfg_default(HAL_SPI2_MOSI);
nrf_gpio_cfg_default(HAL_SPI2_MISO);
all.
uninit_acc_spix();
- When init_acc_spi is remarked - 110uA
- When init_acc_spi is called - 800uA
- When init_acc_spi and uninit_acc_spix is called : 200uA
