Asset Tracker V2, connecting problem to AWS Iot
I am trying to connect asset_tracker_v2 to my aws iot cloud with MQTT,
then storing this data in aws database, when i changing parameters to AWS Iot library,
i have a fatal error, i am not understanding why ?
  • I am workin whit nRF9160, thingy:91 and nRF9160_DK
  • I use nRF Connect SDK V1.8.0 whit SEGGER embedded Studio
  • I have an alredy existing AWS account
  • I have downloaded certificate successfully to µc
That is my configuration:
And that is my log output when building and running:
2021-12-26T14:20:10.118Z INFO Application data folder: C:\Users\Portable\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
2021-12-26T14:20:10.209Z DEBUG App pc-nrfconnect-linkmonitor v2.0.0 official
2021-12-26T14:20:10.209Z DEBUG App path: C:\Users\Portable\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
2021-12-26T14:20:10.209Z DEBUG nRFConnect 3.9.1, required by the app is (^3.8.0)
2021-12-26T14:20:10.209Z DEBUG nRFConnect path: C:\Users\Portable\AppData\Local\Programs\nrfconnect\resources\app.asar
2021-12-26T14:20:10.209Z DEBUG HomeDir: C:\Users\Portable
2021-12-26T14:20:10.209Z DEBUG TmpDir: C:\Users\Portable\AppData\Local\Temp
2021-12-26T14:20:13.457Z INFO Modem port is opened
2021-12-26T14:20:13.471Z DEBUG modem >> AT+CFUN?
2021-12-26T14:20:29.013Z ERROR Opening COM8: Access denied
2021-12-26T14:20:32.530Z INFO Modem port is closed
2021-12-26T14:20:40.120Z INFO Modem port is opened
2021-12-26T14:20:40.128Z DEBUG modem >> AT+CFUN?
2021-12-26T14:20:41.311Z DEBUG modem << *** Booting Zephyr OS build v2.7.0-ncs1  ***
2021-12-26T14:20:41.340Z DEBUG modem << [00:00:00.223,297] [1;33m<wrn> at_notif: Already initialized. Nothing to do[0m
2021-12-26T14:20:41.342Z DEBUG modem << [00:00:00.230,377] [0m<inf> at_host: UART check failed: 13. Dropping buffer and retrying.[0m
2021-12-26T14:20:41.396Z DEBUG modem << [00:00:00.260,162] [0m<inf> event_manager: APP_EVT_START[0m
2021-12-26T14:20:41.398Z DEBUG modem << [00:00:00.281,066] [0m<inf> event_manager: DATA_EVT_CONFIG_INIT[0m
2021-12-26T14:20:41.400Z DEBUG modem << [00:00:00.287,597] [0m<inf> event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
2021-12-26T14:20:41.402Z DEBUG modem << [00:00:00.295,410] [0m<inf> event_manager: MODEM_EVT_INITIALIZED[0m
2021-12-26T14:20:41.541Z DEBUG modem << [00:00:00.310,821] [1;31m<err> aws_iot: Application subscription list count mismatch[0m
2021-12-26T14:20:41.544Z DEBUG modem << [00:00:00.318,634] [1;31m<err> aws_iot_integration: cloud_ep_subscriptions_add, error: -122[0m
2021-12-26T14:20:41.549Z DEBUG modem << [00:00:00.327,087] [1;31m<err> aws_iot_integration: populate_app_endpoint_topics, error: -122[0m
2021-12-26T14:20:41.554Z DEBUG modem << [00:00:00.335,754] [1;31m<err> cloud_module: cloud_wrap_init, error: -122[0m
2021-12-26T14:20:41.559Z DEBUG modem << ASSERTION FAIL [err == 0] @ ../src/modules/cloud_module.c:698
2021-12-26T14:20:41.564Z DEBUG modem << setp() failed
2021-12-26T14:20:41.569Z DEBUG modem << [00:00:00.349,487] [1;31m<err> os: r0/a1:  0x00000004  r1/a2:  0x000002ba  r2/a3:  0x00000001[0m
2021-12-26T14:20:41.574Z DEBUG modem << [00:00:00.358,123] [1;31m<err> os: r3/a4:  0x00026c11 r12/ip:  0x0000a000 r14/lr:  0x0001ca7d[0m
2021-12-26T14:20:41.579Z DEBUG modem << [00:00:00.366,760] [1;31m<err> os:  xpsr:  0x41000000[0m
2021-12-26T14:20:41.592Z DEBUG modem << [00:00:00.371,978] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
2021-12-26T14:20:41.597Z DEBUG modem << [00:00:00.382,354] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
2021-12-26T14:20:41.602Z DEBUG modem << [00:00:00.392,730] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000002[0m
2021-12-26T14:20:41.605Z DEBUG modem << [00:00:00.403,106] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
2021-12-26T14:20:41.607Z DEBUG modem << [00:00:00.413,452] [1;31m<err> os: fpscr:  0x3e2887a6[0m
2021-12-26T14:20:41.609Z DEBUG modem << [00:00:00.418,640] [1;31m<err> os: Faulting instruction address (r15/pc): 0x0003b4d8[0m
2021-12-26T14:20:41.611Z DEBUG modem << [00:00:00.426,513] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0[0m
2021-12-26T14:20:41.613Z DEBUG modem << [00:00:00.434,204] [1;31m<err> os: Current thread: 0x200151c8 (unknown)[0m
That is also my project:
asset_tracker_v2.rar
Thank you for your help
Minyaev
