Hi All,
i am using the below link to flash the bootloader
but it gives me this error when i build
[199/206] Linking C executable zephyr/zephyr_prebuilt.elf
FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr_prebuilt.map
: && ccache /home/user/gnuarmemb/gnu-arm-eabi/bin/arm-none-eabi-gcc zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr/zephyr_prebuilt.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=/home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/home/user/gnuarmemb/gnu-arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/thumb/v7e-m+fp/hard" -L/home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a /home/user/gireesha/workspace/source/gn/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.11.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfpu=fpv4-sp-d16 -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn /home/user/gireesha/workspace/source/gn/ncs/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr && /usr/bin/cmake -E echo
/home/user/gnuarmemb/gnu-arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/zephyr_prebuilt.elf section `text' will not fit in region `FLASH'
/home/user/gnuarmemb/gnu-arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: region `FLASH' overflowed by 13864 bytes
collect2: error: ld returned 1 exit status
[198/213] Linking C executable zephyr/zephyr_prebuilt.elf
[199/213] Generating isr_tables.c, isrList.bin
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr.hex /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr.elf
cd /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot && /usr/bin/cmake --build . --
[202/213] Generating dev_handles.c
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build
Regards
Tushar
