flashing bootloader
Hi All,
i am using the below link to flash the bootloader
https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/device-firmware-update-dfu-with-mcuboot-bootloader
but it gives me this error when i build
[199/206] Linking C executable zephyr/zephyr_prebuilt.elf
FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr_prebuilt.map
: && ccache /home/user/gnuarmemb/gnu-arm-eabi/bin/arm-none-eabi-gcc   zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr/zephyr_prebuilt.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_prebuilt.cmd  -Wl,-Map=/home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr_prebuilt.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/user/gnuarmemb/gnu-arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/thumb/v7e-m+fp/hard"  -L/home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  /home/user/gireesha/workspace/source/gn/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.11.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -no-pie  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  /home/user/gireesha/workspace/source/gn/ncs/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr && /usr/bin/cmake -E echo
/home/user/gnuarmemb/gnu-arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/zephyr_prebuilt.elf section `text' will not fit in region `FLASH'
/home/user/gnuarmemb/gnu-arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: region `FLASH' overflowed by 13864 bytes
collect2: error: ld returned 1 exit status
[198/213] Linking C executable zephyr/zephyr_prebuilt.elf
[199/213] Generating isr_tables.c, isrList.bin
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr.hex /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot/zephyr/zephyr.elf
cd /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build/mcuboot && /usr/bin/cmake --build . --
[202/213] Generating dev_handles.c
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/user/gireesha/workspace/source/gn/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/build
Regards
Tushar
