Network Core access to XIP
My B0n bootloader (running on the network core) is trying to access XIP space and faulting.  This is a part of an network core upgrade.
From what I can learn from the data-sheet, it is clear that:
  • the network core cannot use EasyDMA to access XIP.
  • the network core cannot *execute* from the XIP space
This seems to leave open the possibility that the network core *can* access the XIP space.
My best guess is that there might be some need to give the network core permission to do so using the DCNF and/or SPU. However, the means to do this is not entirely clear from what I can find in the data-sheet documentation.
Are my assumptions correct?
If so, will you kindly point me in the right direction?
I'm using/debugging this sample:
ncs_samples/smp_dfu/ble_extFlash at master · aiminhua/ncs_samples (github.com)
I'm using the nRF5340DK.
The failure/crash happens when I try to upgrade the `net_core_app_update.bin` using the "nRF Connect" DFU on my phone.
I used the Ozone debugger on the network core to find the failure.
