How to check the nRF is connected with MQTT broker or not?
I am facing an issue, I am developing nRF9160 based Product, get sensor data  from peripherals and publish to AWS cloud.my firmware is based on AWS IoT sample. I observed that some time devices get disconnected from AWS.I missed the sensor data during that period.
1.Now I want to save data into SD card  during  that disconnected period.? So I need find Exact point in my application which shows that it is disconnected so I log data into SD card.
2.Once if I done it successfully, log the data then I want to send this file to AWS over MQTT when it again connected?
if I place check on shadow_update ( .So for test purpose I remove the antenna from Device while application is running .its Still updating the Shadow(although message not reached on AWS ).how to kill this issue?
static void shadow_update_work_fn(struct k_work *work)
int err;
err = shadow_update(false);
if (err) {
printk("shadow_update, error: %d\n", err);
printk("Next data publication in %d seconds\n", publication_interval_seconds);
k_delayed_work_submit(&shadow_update_work, K_SECONDS( publication_interval_seconds));
Thanks
