How to check the nRF is connected with MQTT broker or not?
I am facing an issue, I am developing nRF9160 based Product, get sensor data  from peripherals and publish to AWS cloud.my firmware is based on AWS IoT sample. I observed that some time devices get disconnected from AWS.I missed the sensor data during that period.
1.Now I want to save data into SD card  during  that disconnected period.? So I need find Exact point in my application which shows that it is disconnected so I log data into SD card.
2.Once if I done it successfully, log the data then I want to send this file to AWS over MQTT when it again connected?
if I place check on shadow_update ( .So for test purpose I remove the antenna from Device while application is running .its Still updating the Shadow(although message not reached on AWS ).how to kill this issue?
static void shadow_update_work_fn(struct k_work *work)
int err;
err = shadow_update(false);
if (err) {
printk("shadow_update, error: %d\n", err);
printk("Next data publication in %d seconds\n", publication_interval_seconds);
k_delayed_work_submit(&shadow_update_work, K_SECONDS( publication_interval_seconds));
Thanks
  • HI Didrik,
    i am still looking for solution ,not getting the network registration status.
    I am sending CEREG? command after every 5 min
  • I am unable to get modem trace.
    device is not creating the modem trace.
    problem is that.
    let suppose that  I am looking for the network status(by sending command AT+CEREG?) before every publication.
    now I moved the place where no network connectivity available. if they device is placed at the that location for few hour.
    1.if a continuously look for the network status before the shadow update after 1 hour or 2 the device will reboot watch dog reset the device.
    2.if I let suppose moved the device to no network area after connectivity and not send the (CEREG?) command at every publication interval. Still device lock up somewhere and the watch dog reset it.
    3.if I move the device to no coverage area after connected with network ,and put check don't call shadow_ update function until the you get network (by modem it self show connected) then the device is not locking up.but when i moved the device again to coverage area ,device is not going to connect again with network even I placed it here for hours.
    my question is that after how much device itself look for network search? i am using PSM mode
    how can I change modem notification time?
    please
  • Do you at least have some logs from the device showing what is happening?
    Why are you not able to get modem traces?
    Have you set CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y? Do you send the AT%XMODEMTRACE=1,2 command or are you susing the lte_lc library?
    Do you get +CGEV notifications?
  • yes,
    when I am trying to add CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y this give me some at build time  zephyr/include/generated/devicetree_unfixed.h:3321:38: error: 'DT_N_S_soc_S_peripheral_40000000_S_uart_9000_P_tx_pin' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_uart_8000_P_tx_pin'?
    +CGEV not getting Because I am using PSM.
    please found below the attached log
    8233.2022-02-08T15_09_43.710Z-log.txt
