RF interrupt on register retention
Hi, I use nRF24LE1 configured for power down on register retention mode with RFRx active.
When the CPU is on power down i don't have any interrupt from RFIRQ.
Init configuration
IEN1 = 0x22; // interrupt from RTC and RFIRQ
WUCON = 0x0f; // wakeup from RTC and RFIRQ
  void main (void)
    Init();
    for(;;)
     PWRDWN = 0x07;
     Delay(10);
     PWRDWN = 0x04;
  TICK_ISR()
Thank you
    The only mode that can wakeup from RFIRQ is standby-mode (PWRDWN=7), as stated in the nRF24LE1 PS chapter 11.2.
    You are entering a lower sleep mode, register retention, where the only clock source running is the 32 kHz source.
    The reason why you need this sequence when in register retention (timer on):
    PWRDWN = 7;
    PWRDWN = 4;
    is because the RTC peripheral wakes you up on a "pre start time" as it's named in the datasheet. This means that it wakes up the CPU core a given amount of 32 kHz cycles before the interrupt occurs so that you are able to start up your processes and the 16MHz external crystal for radio-usage.
    Cheers, Håkon
