nrf5340 MCUBOOT fails with multi image build at 1.8.0
Hi all,
I observed an issue after upgrading to 1.8.0 and to Zephyr 2.7.0-ncs1 respectively. When having Zigbee (and NET core) enabled, all images are built as before. The external flash is used to store the secondary MCUBOOT image, as defined in the partition file. The app does not seem to start tough.
I could not find much in the release notes beside moving external flash definition to the overlay file.
*** Booting Zephyr OS build v2.7.0-ncs1  ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: none
I: Bootloader chainload address offset: 0xc000
[00:00:00.001,251] <err> os: ***** BUS FAULT *****
[00:00:00.001,251] <err> os:   Precise data bus error
[00:00:00.001,251] <err> os:   BFAR Address: 0x2007fc00
[00:00:00.001,281] <err> os: r0/a1:  0x2000006c  r1/a2:  0x00000000  r2/a3:  0x00000000
[00:00:00.001,281] <err> os: r3/a4:  0x000001ae r12/ip:  0x0000f800 r14/lr:  0x000182a7
[00:00:00.001,281] <err> os:  xpsr:  0x29100000
[00:00:00.001,281] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
[00:00:00.001,312] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
[00:00:00.001,312] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
[00:00:00.001,312] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
[00:00:00.001,342] <err> os: fpscr:  0x20000ed8
[00:00:00.001,342] <err> os: Faulting instruction address (r15/pc): 0x0004bc22
[00:00:00.001,342] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:00:00.001,342] <err> os: Current thread: 0x20001490 (unknown)
 I attached the project (can be compiled with nrf5340dk_nrf5340_cpuapp board).  Any help is appriciated.
hello-world.zip
Milan
