Hello everyone,
I am using the SDK 17.1 with the NRF52832 chip. My current project is created based on the multirole example. My first step was to implement writing and reading out the characteristic values of my custom service. Its working really good but I have a problem now. I worked with delays between the function call of e.g sd_ble_gattc_read() and the event response. With this method I was able to test the general functionality. But I cannot use this method in my real software because I get sometimes the error code "NRF_ERROR_BUSY". From my understanding I get this error because of a overload of the softdevice. Is there any possibility to fix this issue and get a stable and fast data exchange?
Currently I am trying to implement the Queued Read and Write. I try to implement it according to the BLE GATT QUEUE MSC and DIS Client. But I dont get the complete picture and the sequence. I am able to trigger the event but the data within the Event is wrong. My MTU is 247 and the character which I want to read has 500 Bytes. With the sd_ble_gattc_read() function I was able to work with offset and it worked really well. How can I read the complete character? It looks like with the Queue read method I am able to read without offset that means maximum MTU size?
I am a little bit confused and I hope you can support me to implement the writing and reading in the best way.
ret_code_t ble_hrs_c_read(ble_hrs_c_t * p_ble_hrs_c)
ret_code_t err_code;
nrf_ble_gq_req_t hrs_c_req;
VERIFY_PARAM_NOT_NULL(p_ble_hrs_c);
memset(&hrs_c_req, 0, sizeof(hrs_c_req));
hrs_c_req.type = NRF_BLE_GQ_REQ_GATTC_READ;
hrs_c_req.error_handler.cb = gatt_error_handler;
hrs_c_req.error_handler.p_ctx = p_ble_hrs_c;
hrs_c_req.params.gattc_read.handle = p_ble_hrs_c->peer_hrs_db.hrm_handle;
err_code = nrf_ble_gq_item_add(p_ble_hrs_c->p_gatt_queue, &hrs_c_req, p_ble_hrs_c->conn_handle);
return err_code;
Best Regards
Hani
