add timer in ble_app_uart
I am working on adding a timer in the ble_app_uart sample, aiming on disconnect with device which doesn't send any data in specific time, such as 5 seconds.
Now I have found an example "timer_pca10028", and try to insert useful part into my application. here is my mofified main function:
    uint32_t err_code;
    bool erase_bonds;
    uint8_t  start_string[] = START_STRING;
    // Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    printf("%s",start_string);
		err_code = nrf_drv_timer_init(&TIMER_LED, NULL, timer_data_receive_event_handler);
    //APP_ERROR_CHECK(err_code);
		uint32_t time_ticks;
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, DATA_RECEIVE_TIMEOUT);
    nrf_drv_timer_extended_compare(
         &TIMER_LED, NRF_TIMER_CC_CHANNEL0, DATA_RECEIVE_TIMEOUT, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
		err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
        power_manage();
timer_data_receive_event_handler is my timer event handler, when I find the time is out and it doesn't get any message, 51822 terminates connection, :
void timer_data_receive_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch(event_type)
				uint32_t  err_code;
        case NRF_TIMER_EVENT_COMPARE0:
						if (!is_received_data){
							nrf_drv_timer_disable(&TIMER_LED);
            //Do nothing.
is_received_data is used for marking if I have received the data in nus_data_handler()
when the connection is established, I will start a timer like that:
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
        case BLE_GAP_EVT_CONNECTED:
						printf("%s","Device Connected:");
						nrf_drv_timer_enable(&TIMER_LED);
Now I have two problem:
  1. Does the sample "timer_pca10028" match my purpose? Can I set a timer imitating the sample code?
  2. nrf_drv_timer_enable(&TIMER_LED) in on_ble_evt cause the disconnection with mobile phone. If I remove this line, my application works as a normal ble_app_uart application at least. However when I enable it, the nrf UART app connects to the 51822 and disconnect automatically at the same time. But the LED on the dongle shows it is in a connected mode.
Could anyone help me? Thanks in advance!
  • I have not gone through the whole code, but these are the mistakes I could point out
             &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks , NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    The above function takes ticks values NOT DATA_RECEIVE_TIMEOUT
    1. which function is reseting is_received_data, i think it should be done in timer handler
      case NRF_TIMER_EVENT_COMPARE0: if (!is_received_data){ err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); nrf_drv_timer_disable(&TIMER_LED); } else { is_received_data = 0; // reset it so that it is useful for next comparision }
    update_28.07.15
    I copied your code into ble_app_uart and added just one printf , it just worked ok image description The device is advertising and no hangs. I used S130 available in SDK9.0 on pca_100028. Check if you have not changed anything in app_uart, or better, try your code on fresh SDK9.0
  • yiran, could you post a working example now? I have the same problem as you did and I can't make sense of this code-mixing.
