Executing sd_ble_gatts_value_set will result in BLE_ERROR_INVALID_CONN_HANDLE
Hello.
I'm using nrf52832 (S132 v7.0.1, SDK v17.0.0) to develop peripheral roles.
I want to create a characteristic with the Read settings assigned and set the data to it. Therefore, I am using sd_ble_gatts_value_set, but it becomes BLE_ERROR_INVALID_CONN_HANDLE. The following code is the code that causes an error.ble_write_req is called after the characteristic is created.
// UUID Setting
#define ADV_UUID_BASE     {0x77, 0x77, 0x66, 0x66, 0x55, 0x55, 0x44, 0x44, 0x33, 0x33, 0x22, 0x22, 0x11, 0x11, 0x00, 0x00}
#define SERVICE_UUID_BASE {0xHH, 0xHH, 0xGG, 0xGG, 0xFF, 0xFF, 0xEE, 0xEE, 0xDD, 0xDD, 0xCC, 0xCC, 0xBB, 0xBB, 0xAA, 0xAA}
// Characteristic params
static ble_add_char_params_t add_char_params =
    .uuid            = 0xYYYY,
    .uuid_type       = NULL,
    .max_len         = 248,
    .init_len        = 248,
    .is_var_len      = false,
    .char_props.read = 1,
    .read_access     = SEC_OPEN,
static uint16_t                 m_service_handle; /**< Handle of local service (as provided by the BLE stack).*/
static ble_gatts_char_handles_t m_char_handles;   /**< Handles of local characteristic (as provided by the BLE stack).*/
// Write Request
static void ble_write_req(void)
    ret_code_t        err_code;
    ble_gatts_value_t char_value;
    char *            test_value;
    test_value = "test";
    char_value.len     = sizeof(test_value);
    char_value.offset  = 0;
    char_value.p_value = (uint8_t *)&test_value;
    err_code = sd_ble_gatts_value_set(m_service_handle, m_char_handles.value_handle, &char_value);
    return;
I don't know why it's an error. Can you tell me?
Best regards.
