modem lte_lc_offline , lte_lc_normal()
Dear Sir.
I use these commands to connect the Modem ON and OFF.
I need to know  if the result of the these commands the Modem communicates with the Cell tower ?
Please Advide.
  • Hello Ephraim,
    I’m not quite sure if I fully understand your question. But yes, lte_lc_normal() basically is a wrapper for AT+CFUN=1, setting the modem to normal operation mode. lte_lc_offline() however, will not result in search for a network, but send the modem to offline mode.
    Markus
  • Hi.
    We are testing our custopm board which has printed antenna ,
    current consumption during TX .
    1. If in line of sight with the cell tower , current is 5 to 10 ma.
    2. outdoor 40 to 60 ma.
    3. Inside building 350 to 500 ma.
    I know that the Modem and cell tower negotiate  to detrmeine the Modec tx power needed.
    Which routine is responsible for it ?.
    What realy happens with the command lte_lc_normal()  ?.
    Does is communicate wit the Cell tower ?.
    Thanks
  • Hello Ephraim,
    Well, the modem and network negotiate about Active Time and Tracking Area Update for Power Saving Mode (PSM). But this is not connected to a specific tx power value, as this can differ quite a lot.
    The responsible interface for this is the AT commando +CPSMS. The result of the negotiation can be visualised via +CEREG, with unsolicited result codes enabled on level 4 or 5.
    It is a wrapper running the AT command “AT+CFUN=1”, which sets the modem to full functionality.
    Yes.
    Markus
