Cannot configure the build system to include X509 functions
I'm working on a simple app that is supposed to generate a CSR and have it signed by a web server.
The problem is, I can't even get zephyr to build the components I need, as there seems to be some sort of circular dependency in Kconfig.
When I want to select MBEDTLS_X509_CSR_WRITE_C via menuconfig, I am forced to enable MBEDTLS_X509_LIBRARY, NRF_SECURITY_ADVANCED, NRF_SECURITY_ANY_BACKEND, and NORDIC_SECURITY_BACKEND to even get there. But if I correctly understand the help text for that symbol, all these need to be disabled. Which would explain, that after saving that configuration (which prompts no complaints from west or ninja), the build will fail, and even re-configuration via `west build -t menuconfig` fails with the same error message, and the only way to recover is to restore .config from .config.old.
Is this really broken or am I just missing something?
Best Regards and thanks in advance,
Alex
    Those configs need to be enabled in order to use MBEDTLS_X509_CSR_WRITE_C : https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/kconfig/CONFIG_MBEDTLS_X509_CSR_WRITE_C.html
    What is the error you are seeing when you try to build? Can you attach the build log here?
  • of course. here you are:
    $ west build
    [0/1] Re-running CMake...
    Including boilerplate (Zephyr base (cached)): /path_to/src/project/ncs/zephyr/cmake/app/boilerplate.cmake
    -- Application: /path_to/src/project/ncs/nrf9160-button
    -- Zephyr version: 2.7.0 (/path_to/src/project/ncs/zephyr), build: v2.7.0-ncs1-rc2
    -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
    -- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
    -- Cache files will be written to: /path_to/.cache/zephyr
    -- Using toolchain: zephyr 0.13.1 (/opt/zephyr-sdk-0.13.1)
    -- Found dtc: /opt/zephyr-sdk-0.13.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /path_to/src/project/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: /path_to/src/project/ncs/nrf9160-button/boards/nrf9160dk_nrf9160_ns.overlay
    nrf9160dk_nrf9160_ns.dts.pre.tmp:367.32-371.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
    -- Generated zephyr.dts: /path_to/src/project/ncs/nrf9160-button/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /path_to/src/project/ncs/nrf9160-button/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /path_to/src/project/ncs/nrf9160-button/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: /path_to/src/project/ncs/nrf9160-button/build/zephyr/dts.cmake
    Parsing /path_to/src/project/ncs/nrf9160-button/Kconfig
    Loaded configuration '/path_to/src/project/ncs/nrf9160-button/build/zephyr/.config'
    warning: Experimental symbol NET_SOCKETS_OFFLOAD is enabled.
    warning: MBEDTLS_PK_C (defined at /path_to/src/project/ncs/nrfxlib/nrf_security/Kconfig:1573) has direct dependencies MBEDTLS_TLS_LIBRARY && NRF_SECURITY_ADVANCED && NRF_SECURITY_ANY_BACKEND && NORDIC_SECURITY_BACKEND with value n, but is currently being y-selected by the following symbols:
     - MBEDTLS_X509_LIBRARY (defined at /path_to/src/project/ncs/nrf/modules/trusted-firmware-m/Kconfig.mbedtls_minimal.defconfig:12, /path_to/src/project/ncs/nrfxlib/nrf_security/Kconfig:45), with value y, direct dependencies TFM_MINIMAL || NORDIC_SECURITY_BACKEND (value: y), and select condition NORDIC_SECURITY_BACKEND (value: y)
    error: Aborting due to Kconfig warnings
    CMake Error at /path_to/src/project/ncs/zephyr/cmake/kconfig.cmake:270 (message):
      command failed with return code: 1
      /path_to/src/project/ncs/zephyr/cmake/app/boilerplate.cmake:546 (include)
      /path_to/src/project/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      /path_to/src/project/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
      CMakeLists.txt:9 (find_package)
    See also "/path_to/src/project/ncs/nrf9160-button/build/CMakeFiles/CMakeOutput.log".
    See also "/path_to/src/project/ncs/nrf9160-button/build/CMakeFiles/CMakeError.log".
    FAILED: build.ninja
    /usr/bin/cmake --regenerate-during-build -S/path_to/src/project/ncs/nrf9160-button -B/path_to/src/project/ncs/nrf9160-button/build
    ninja: error: rebuilding 'build.ninja': subcommand failed
    FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /path_to/src/project/ncs/nrf9160-button/build
  • Looks like another config is missing, I'm guessing that it's CONFIG_MBEDTLS_TLS_LIBRARY.
    You can try adding that config, or look up MBEDTLS_PK_C in menuconfig and check which dependency is missing there.
  • That seemed to help, but now I'm getting a linker error:
    [236/245] Linking C executable zephyr/zephyr_prebuilt.elf
    FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map /path_to/src/project/ncs/nrf9160-button/build/zephyr/zephyr_prebuilt.map
    : && ccache /opt/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc   zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr/zephyr_prebuilt.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  tfm/secure_fw/s_veneers.o  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_prebuilt.cmd  -Wl,-Map=/path_to/src/project/ncs/nrf9160-button/build/zephyr/zephyr_prebuilt.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/boards/boards/arm/nrf9160dk_nrf9160_ns/libboards__arm__nrf9160dk_nrf9160.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a  modules/nrf/lib/at_monitor/lib..__nrf__lib__at_monitor.a  modules/nrf/lib/at_cmd_parser/lib..__nrf__lib__at_cmd_parser.a  modules/nrf/lib/lte_link_control/lib..__nrf__lib__lte_link_control.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/lib/modem_key_mgmt/lib..__nrf__lib__modem_key_mgmt.a  modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a  modules/trusted-firmware-m/libtfm_api.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  /path_to/src/project/ncs/nrfxlib/nrf_modem/lib/cortex-m33/soft-float/libmodem.a  modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v8-m.main/nofp"  -L/path_to/src/project/ncs/nrf9160-button/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  tfm/platform/libplatform_ns.a  tfm/app/libtfm_api_ns.a  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -no-pie  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  spm/libspmsecureentries.a  -lm  -Wl,-lc  -L"/opt/zephyr-sdk-0.13.1/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v8-m.main/nofp  -Wl,-lgcc  -lc  -lgcc  -specs=nano.specs  modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/libmbedtls.a  modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/libmbedx509.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a  -lc  -L && cd /path_to/src/project/ncs/nrf9160-button/build/zephyr && /usr/bin/cmake -E echo
    arm-zephyr-eabi-gcc: error: missing argument to '-L'
    I guess that's ... progress?
  • Same error if you delete the build folder and rebuild?
