BLE Button low power
Hello fellow developers,
I am new to BLE applications and I am trying to do a very simple device with three buttons that informs a Android smartphone when one has been pressed. So far, I got everything running: the android part, the nRF51822 application on mbed (BLE_Button) and so far everything connects and every time I press the button the application shows the notification :-D
The problem comes with the power consumption: it's around 0.60 uA when advertising (which seems OK to me) and rises to 160-200 uA when the device is paired with the Android application. I wonder if there is a way to drop that consumption when the device is connected to lower values as it seems to be pretty high to me.
Is there a way to configure the device to sleep as much as possible, while keeping the communication channel open and wake up only to send the notification? Should that configuration be done in the Android part or in the nRF51 code?
If it's not possible to lower the power consumption when connected: would it be a better solution to sleep the device and wake up to send Beacons/GAP to the central device and then sleep again. The information I have to transmit is little enough to fit in that model, I just don't know if it is a valid solution architecture (delivery is not guaranteed).
I have tried by reducing the latency but I did not get any changes. Maybe I need to change something on the Android application? Should these parameters be changed before starting the advertisement or when the device has been connected?
Gap::ConnectionParams_t new_params;
ble.gap().getPreferredConnectionParams(&new_params);
new_params.minConnectionInterval = BLE_GAP_CP_MIN_CONN_INTVL_MAX;
new_params.maxConnectionInterval = BLE_GAP_CP_MAX_CONN_INTVL_MAX;
new_params.slaveLatency = BLE_GAP_CP_SLAVE_LATENCY_MAX;
new_params.connectionSupervisionTimeout = BLE_GAP_CP_CONN_SUP_TIMEOUT_MAX;
ble.gap().setPreferredConnectionParams(&new_params);
Thanks all for your time. Best regards,
P/S: I am not tied to mbed development and I'm OK with trying different APIs or examples if you think that the power consumption would be lower (how little should it be? around 10 uA?).
