Two bugs or problems report with Direction Finding
In the latest SDK version v1.8.0, I have developed my own project based on direction_finding_connectionless_rx demo. Here are two problems I countered.
1. the RSSI attribute of variable report in the cte_recv_cb function always return the value of -1270. Meanwhile, the RSSI in the recv_cb always returns -127.
as showed below:
2. In the prj.conf file, if I set variable CONFIG_BT_PER_ADV_SYNC_MAX to 8, the build process goes well. However, it is 10, the error occuried with following log information:
FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map
cmd.exe /C "cd . && C:\Users\Marcous\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-gcc.exe   zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf  -Wl,-T  zephyr/linker_zephyr_prebuilt.cmd  -Wl,-Map=E:/nordic_demo/multi_sync_demo/build/zephyr/zephyr_prebuilt.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"c:/users/marcous/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v7e-m/nofp"  -LE:/nordic_demo/multi_sync_demo/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -no-pie  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn && cmd.exe /C "cd /D E:\nordic_demo\multi_sync_demo\build\zephyr && C:\Users\Marcous\ncs\v1.8.0\toolchain\opt\bin\cmake.exe -E echo ""
c:/users/marcous/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr\zephyr_prebuilt.elf section `bss' will not fit in region `SRAM'
c:/users/marcous/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `SRAM' overflowed by 23801 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\Users\Marcous\ncs\v1.8.0\toolchain\opt\bin\cmake.EXE' --build 'e:\nordic_demo\multi_sync_demo\build'
It seemed somehow the SRAM is overflowed, but I cant figure out how to fix this. Since I set the same variable to 10 with SDK version v1.6.0, and it goes well.
Following is the code I added to the prj.conf file
# prj.conf
CONFIG_BT=y
CONFIG_BT_DEVICE_NAME="DF Connectionless Locator App"
CONFIG_BT_EXT_ADV=y
CONFIG_BT_PER_ADV_SYNC=y
CONFIG_BT_OBSERVER=y
# Enable Direction Finding Feature including AoA and AoD
CONFIG_BT_DF=y
CONFIG_BT_DF_CONNECTIONLESS_CTE_RX=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_SYNC_PERIODIC=y
CONFIG_BT_CTLR_DF=y
CONFIG_BT_CTLR_DF_ANT_SWITCH_TX=n
CONFIG_BT_PER_ADV_SYNC_MAX=10
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
and here is the code in file overlay-aod.conf
# Disable AoD Feature (antenna switching) in Tx mode
CONFIG_BT_CTLR_DF_ANT_SWITCH_RX=n
By the way, I also tink a little bit with the zephyr/subsys/bluetooth/controller/hci/hci.c and zephyr/subsys/bluetooth/controller/ll_sw/ull.c following the github zephyr upstream main branch Bluetooth: controller: ULL: fix dequeue of IQ samples reports.
