I am facing below AT_cmd errors after flashing my application to nRF9160 DK. Please support me how to resolve these errors asap as its blocking our product development activity.
I want to setup the MAGPIO in the main function before calling the LwM2M carrier events. But looks like AT is not getting initialized unless and until DK board is not connected with LTE via LwM2M carrier. If I send same AT command after LTE connected to network then the AT command will work and will not throw any errors which is more confusing to me.
Errors:
<err> at_cmd: Failed to open AT socket (err:-117)
<err> at_cmd: Failed to send AT command (err:9)
Reference code: (Note: This is just a reference code where I just want to share that how exactly I am want to setup the MAGPIO in main() )
/* Standard includes files */
#include <random/rand32.h>
#include <stdbool.h>
#include <stdio.h>
#include <string.h>
/* Modem/Network includes files */
#include <modem/at_cmd.h>
#include <modem/at_notif.h>
#include <modem/lte_lc.h>
#include <net/mqtt.h>
#include <net/socket.h>
/* Zephyr includes files */
#include <zephyr.h>
#include <zephyr/types.h>
/* FOTA includes files */
#include <dfu/dfu_target_mcuboot.h>
#include <dfu/mcuboot.h>
#include <modem/nrf_modem_lib.h>
#include <net/fota_download.h>
/* Driver include files */
#include <device.h>
#include <drivers/uart.h>
#include <nrfx.h>
#include <secure_services.h>
#include <drivers/clock_control.h>
#include <drivers/clock_control/nrf_clock_control.h>
#define AT_MAGPIO "AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586"
const char *const at_commands_magpio[] = {
AT_MAGPIO,
/* To strictly comply with UART timing, enable external XTAL oscillator */
void enable_xtal(void)
struct onoff_manager *clk_mgr;
static struct onoff_client cli = {};
clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
sys_notify_init_spinwait(&cli.notify);
(void)onoff_request(clk_mgr, &cli);
int hubo_setup_modem_magpio(void) {
char buf[50];
for (int i = 0; i < ARRAY_SIZE(at_commands_magpio); i++) {
/* send one by one AT commands to modem and check if success or failed */
if (at_cmd_write(at_commands_magpio[i], buf, sizeof(buf), NULL) != 0) {
LTE_DEBUG_PRINTK("AT Command: %s Failed with Response: %s\n", at_commands_magpio[i], buf);
return -1;
return 0;
void main(void) {
enable_xtal();
/* control an external antenna tuner by setting MAGPIO pins to support all LTE frequncy ranges. */
if (hubo_setup_modem_magpio() != 0) {
printk("Failed to initialize MAGPIO Configuration.\n\n");
uart_task_init(); // UART setup for serial communication
nvs_init();
while (1) {
k_sleep(K_MSEC(1000));
Menuconfig for AT_CMD:
prj.conf file
CONFIG_FPU=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_STDOUT_CONSOLE=y CONFIG_AT_CMD=y # DK CONFIG_DK_LIBRARY=y CONFIG_LWM2M_CARRIER=y CONFIG_NRF_MODEM_LIB_SYS_INIT=n CONFIG_AT_CMD_THREAD_STACK_SIZE=1536 # PDN library CONFIG_PDN=y CONFIG_PDN_CONTEXTS_MAX=3 # Disable NB-IoT fallback CONFIG_LTE_NETWORK_USE_FALLBACK=n # SMS library CONFIG_SMS=y # LwM2M carrier is only compiled for hard-float CONFIG_FPU=y CONFIG_FP_HARDABI=y # Networking CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n CONFIG_LTE_PSM_REQ_RPTAU="00011111" CONFIG_LTE_PSM_REQ_RAT="00000010" # Modem library CONFIG_NRF_MODEM_LIB=y # FOTA library CONFIG_FOTA_DOWNLOAD=y CONFIG_REBOOT=y # Download client CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 # DFU Target CONFIG_DFU_TARGET=y # Application Upgrade support CONFIG_BOOTLOADER_MCUBOOT=y # Image manager CONFIG_IMG_MANAGER=y CONFIG_IMG_ERASE_PROGRESSIVELY=y # Day-Time library CONFIG_DATE_TIME=y CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=3600 # AT Host CONFIG_AT_CMD_PARSER=y CONFIG_AT_HOST_LIBRARY=y # Serial port CONFIG_SERIAL=y CONFIG_UART_NRFX=y CONFIG_UART_INTERRUPT_DRIVEN=y # Have kernel output CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0" # MQTT CONFIG_MQTT_LIB=y CONFIG_MQTT_LIB_TLS=y CONFIG_MQTT_CLEAN_SESSION=y CONFIG_MODEM_KEY_MGMT=y # Memory CONFIG_MAIN_STACK_SIZE=8192 CONFIG_HEAP_MEM_POOL_SIZE=8192 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 #GPIO required for GPS Amplifier enable/disable CONFIG_GPIO=y #Threads CONFIG_MULTITHREADING=y CONFIG_MAIN_THREAD_PRIORITY=7 #Disable UART CONFIG_BOOT_BANNER=y CONFIG_PRINTK=y CONFIG_LOG=y # Storage CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_NVS=y CONFIG_NVS_LOG_LEVEL_DBG=y CONFIG_REBOOT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # GPS CONFIG_NRF9160_GPS=y CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y # AGPS CONFIG_AGPS=y # CONFIG_AGPS_SRC_SUPL=y CONFIG_AGPS_LOG_LEVEL_DBG=y CONFIG_NRF9160_GPS_THREAD_STACK_SIZE=4608 # Compiler CONFIG_NEWLIB_LIBC=y
Console Logs:
I: Starting bootloader I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Boot source: none I: Swap type: none I: Bootloader chainload address offset: 0x10000 *** Booting Zephyr OS build v2.6.0-rc1-ncs1 *** Flash regions Domain Permissions 00 03 0x00000 0x20000 Secure rwxl 04 31 0x20000 0x100000 Non-Secure rwxl Non-secure callable region 0 placed in flash region 3 with size 32. SRAM region Domain Permissions 00 07 0x00000 0x10000 Secure rwxl 08 31 0x10000 0x40000 Non-Secure rwxl Peripheral Domain Status 00 NRF_P0 Non-Secure OK 01 NRF_CLOCK Non-Secure OK 02 NRF_RTC0 Non-Secure OK 03 NRF_RTC1 Non-Secure OK 04 NRF_NVMC Non-Secure OK 05 NRF_UARTE1 Non-Secure OK 06 NRF_UARTE2 Secure SKIP 07 NRF_TWIM2 Non-Secure OK 08 NRF_SPIM3 Non-Secure OK 09 NRF_TIMER0 Non-Secure OK 10 NRF_TIMER1 Non-Secure OK 11 NRF_TIMER2 Non-Secure OK 12 NRF_SAADC Non-Secure OK 13 NRF_PWM0 Non-Secure OK 14 NRF_PWM1 Non-Secure OK 15 NRF_PWM2 Non-Secure OK 16 NRF_PWM3 Non-Secure OK 17 NRF_WDT Non-Secure OK 18 NRF_IPC Non-Secure OK 19 NRF_VMC Non-Secure OK 20 NRF_FPU Non-Secure OK 21 NRF_EGU1 Non-Secure OK 22 NRF_EGU2 Non-Secure OK 23 NRF_DPPIC Non-Secure OK 24 NRF_REGULATORS Non-Secure OK 25 NRF_PDM Non-Secure OK 26 NRF_I2S Non-Secure OK 27 NRF_GPIOTE1 Non-Secure OK SPM: NS image at 0x20200 SPM: NS MSP at 0x20034aa0 SPM: NS reset vector at 0x31f19 SPM: prepare to jump to Non-Secure image. *** Booting Zephyr OS build v2.6.0-rc1-ncs1 *** AT Command: AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586 Failed with Response: « Failed to initialize MAGPIO Configuration. [00:00:00.004,760] <err> at_cmd: Failed to open AT socket (err:-117) [00:00:00.027,618] <err> at_cmd: Failed to send AT command (err:9) [00:00:00.022,766] <dbg> fs_nvs.nvs_recover_last_ate: Recovering last ate from sector 0 [00:00:00.027,526] <inf> fs_nvs: 3 Sectors of 4096 bytes [00:00:00.027,526] <inf> fs_nvs: alloc wra: 0, 998 [00:00:00.027,557] <inf> fs_nvs: data wra: 0, 328
NCS version : 1.6.0
Modem Firmware version: 1.2.3
Device Revision : NRF9160_xxAA_REV2
Board Version : PCA10090
Chetan
