I want use 3 block flash. each size is 16bytes. My code as below
check_ant_gpio_mode();
if(factory_dm_mode == 1)
power_check();
sense_gpio_init();
control_uart_init();
adc_configure();
//Peer manager init,then we can connect BLE
peer_manager_init(true);
utils_setup();
softdevice_setup();
factory_control_dynamometer();
void factory_control_dynamometer()
uint32_t err_code;
static uint16_t omega = 0; // angular velocity to be set, unit is rpm
while(1)
if(start_test == 0)
start_test = 1;
pstorage_data_init();
pstorage_torque_0_clear();
pstorage_torque_w_clear();
pstorage_torque_i_clear();
static void example_cb_handler(pstorage_handle_t *handle,
uint8_t op_code,
uint32_t result,
uint8_t *p_data,
uint32_t data_len)
if(handle->block_id == pstorage_torque_0_wait_handle)
pstorage_torque_0_wait_flag = 0;
else if(handle->block_id == pstorage_torque_w_wait_handle)
pstorage_torque_w_wait_flag = 0;
else if(handle->block_id == pstorage_torque_i_wait_handle)
pstorage_torque_i_wait_flag = 0;
static void pstorage_data_init(void)
uint32_t retval;
//1. torque_0 array: 16x4 => 2 x 18 x 2bytes + 2 bytes header => 74 Bytes
//2. torque_w array: 2x2 => 2 x 2 x 2bytes + 2bytes contact + 2 bytes header => 12 Bytes
//3. torque_i array: 2x2 => 2 x 11 x 2bytes + 2bytes contact + 2 bytes header => 48 Bytes
param.block_size = 16;
param.block_count = 3;
param.cb = example_cb_handler;
retval = pstorage_register(¶m, &pstorage_handle);
pstorage_block_identifier_get(&pstorage_handle, 0, &block_torque_0_handle);
pstorage_torque_0_wait_handle = block_torque_0_handle.block_id;
pstorage_block_identifier_get(&pstorage_handle, 1, &block_torque_w_handle);
pstorage_torque_w_wait_handle = block_torque_w_handle.block_id;
pstorage_block_identifier_get(&pstorage_handle, 2, &block_torque_i_handle);
pstorage_torque_i_wait_handle = block_torque_i_handle.block_id;
static void pstorage_torque_0_clear(void)
uint32_t retval;
pstorage_torque_0_wait_flag = 1;
retval = pstorage_clear(&block_torque_0_handle, 16);
while(pstorage_torque_0_wait_flag)
//nrf_delay_ms(10);
static void pstorage_torque_w_clear(void)
uint32_t retval;
pstorage_torque_w_wait_flag = 1;
retval = pstorage_clear(&block_torque_w_handle, 16);
while(pstorage_torque_w_wait_flag)
//nrf_delay_ms(10);
static void pstorage_torque_i_clear(void)
uint32_t retval;
pstorage_torque_i_wait_flag = 1;
retval = pstorage_clear(&block_torque_i_handle, 16);
while(pstorage_torque_i_wait_flag)
//nrf_delay_ms(10);
When I call pstorage_torque_0_clear(). I can get flag change from callback function.
but then call pstorage_torque_1_clear(). I can not get flag change from callback function.
I think the callback function did not enter this. Why?
