Hi All,
Currently I'm editing an example project using the NRF5 SDK in SES -- however, I'm not sure exactly how to best version a project or even export it to contain all of the necessary source files for compilation in a command line environment.
For example, In a typical Eclipse project, I usually don't use relative references to files and the project itself exists and is contained along with all the necessary source files.
In the NRF5 SDK, the SES project within a given example seems to be lightly coupled with the required source files which exist in various other parts of the SDK. Is there an easy way I can export a given project to an archive that includes only the necessary files to compile that given project?
I'm still learning how projects are setup in the NRF5 SDK and SES.
As a note, I'm specifically addressing NRF5 and not the NRF Connect SDK as the NRF5 SDK has examples I needed to reference for a project I'm working on.
Thank you!
