MCUBoot’s secondary image on external flash on nrf9160
I am using nrf9160 custom board with an external flash memory mx25l6433f. I first tested the external flash with the example 'sdk-zephyr/samples/drivers/spi_flash_at45' and for it to work was added an '.overlay'
&spi3 {
	status = "okay";
	sck-pin = <8>;
	mosi-pin = <11>;
	miso-pin = <10>;
	cs-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
	mx25l64: mx25l6433f@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <8000000>;
		label = "MX25L64";
		jedec-id = [c2 20 17];
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <67108864>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
and on my 'proj.conf' added
# Test ext Flash
CONFIG_SPI=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_SPI_NOR=y
Compiled and tested. The external flash is working.
After this i tried to implement 'MCUBOOT secondary on external flash', after reading several posts i ended with this configurations:
nrf9160dk_nrf9160_ns.overlay
&spi3 {
	status = "okay";
	sck-pin = <8>;
	mosi-pin = <11>;
	miso-pin = <10>;
		reg = <0>;
		label = "MX25L64";
		sfdp-bfp = [
		size = <67108864>;
		has-dpd;
	chosen {
		nordic,pm-ext-flash = &mx25l64;
prj.conf
# Test ext Flash
CONFIG_SPI=y
CONFIG_FLASH=y
CONFIG_SPI_NOR=y
# set mcuboot_secondary on external flash
# This value must match the size of the MCUboot primary partition
CONFIG_PM_PARTITION_SIZE_MCUBOOT_SECONDARY=0xe0000
mcuboot.conf
# Enable flash operations
CONFIG_FLASH=y
# This value must match the size of the MCUboot primary partition.
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
In the end, after applying the changes my flash space doubled the amount and on 'build\build_nrf9160dk_nrf9160_ns\partitions.yml' we can see the external flash and mcuboot secondary on external flash
external_flash:
  address: 0xe0000
  end_address: 0x800000
  region: external_flash
mcuboot:
  address: 0x8200
  end_address: 0x10000
  placement:
    before:
    - mcuboot_primary
  region: flash_primary
  sharers: 0x1
mcuboot_pad:
  address: 0x18000
  end_address: 0x18200
  placement:
    align:
      start: 0x8000
    before:
    - mcuboot_primary_app
  sharers: 0x2
mcuboot_primary:
  address: 0x18000
  end_address: 0xf8000
  orig_span: &id002
  - mcuboot_pad
  - app
  - spm
  span: *id002
mcuboot_primary_app:
  address: 0x18200
  orig_span: &id003
  - app
  - spm
  span: *id003
mcuboot_secondary:
  address: 0x0
  device: MX25L64
  end_address: 0xe0000
  placement:
    align:
      start: 0x4
Then i programmed it to nrf9160 and it doesn't boot.
In one of the attempts to put it to work i removed the line 'CONFIG_PM_PARTITION_SIZE_MCUBOOT_SECONDARY=0xe0000' from mcuboot.conf and programmed it to nrf9160, this time it booted and started the program, but when i tried to update the firmware through DFU it says there is not enough space to store the update
Is this a bug, or did I simply went off track somewhere? Thanks.
  • Hi Rokk research,
    That is strange, because i follow the example that Simon gave and it's working
    In nRF9160: HTTP application update using the nRF9160DK's external flash, I have modified the http_update/application_update sample to support MCUboot updates using the 91DK's onboard external flash as secondary slot. I tested this sample with NCS v1.7.0, but I guess it will work fine with NCS v1.8.0 as well.
    Test it yourself by following the steps under Testing
    See here my partition file.
    b0_container:
      address: 0x0
      end_address: 0x8000
      orig_span: &id001
      - b0
      span: *id001
    external_flash:
      address: 0x100000
    mcuboot:
      address: 0x8200
      placement:
        before:
        - mcuboot_primary
      sharers: 0x1
    mcuboot_pad:
      address: 0x18000
      placement:
        align:
          start: 0x8000
        before:
      sharers: 0x2
    mcuboot_primary:
      address: 0x18000
      orig_span: &id002
      - spm
      - app
      - mcuboot_pad
      span: *id002
      address: 0x18200
      orig_span: &id003
      - app
      - spm
      span: *id003
    mcuboot_secondary:
      address: 0x0
      device: MX25L64
      end_address: 0x100000
      placement:
        align:
          start: 0x4
    Note that 'External flash' has decreased the size because of 'mcuboot_secondary' and the size of 'mcuboot_primary_app' is 0xdfe00 (916 992B).
    I've made several FOTA updates on the client with no errors and didn't use any patch.
    There must be something else missing on your configurations
    # Ext Flash
    CONFIG_SPI=y
    #CONFIG_FLASH=y
    CONFIG_SPI_NOR=y
    CONFIG_PM_PARTITION_SIZE_MCUBOOT_SECONDARY=0x100000
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=32
    This is what i add to my 'prj.conf'
  • Hi ICM_UC, that 's very interesting!!  Thanks for the info, I will try to figure out what the difference is.  I simply cloned the repo and tried to build the same (targeting the nRF9160 DK) without any modifications, but I will double check the configs.
  • Hi Rokk Research,
    Just take into account the link Simon gave is for a repo that is modified. If you go to your SDK the sample is a bit different, mainly the 'proj.conf'
