How to connect to a Windows 8 PC
I`ve got a working S120 peripheral BLE device with custom services and characteristics. I am able to connect and bond with iOS and Android. But I cannot connect to Windows7 / Windows8. The device will not be visible in the windows device API. I did some research with some other BLE devices (custom raspberryPI as BLE device). There I get a working connection by the windows device API.
I found this other DevZone topic regarding Windows8 connection: link text
But when I change the
m_sec_params.kdist_periph.enc = 1; m_sec_params.kdist_periph.id = 1; m_sec_params.kdist_periph.sign = 0;
parameters as suggested, I can not bond my device to Android or iOS any more...!? Do you guys have any idea? Where is my mistake?
Regards, BTprogrammer
  • Can you see the device advertising on Windows at all? Is it just so that you can't pair with it? If so I had the same problem. Implementing a device manager helped. There's an example showing how it's done.
  • Hello, sorry but I don`t know how to implement a device manager on my peripheral application. For me, the device manger is a software module that handles connections from a central device to a peripheral device. Is there an example, where the device manager is used in a peripheral application?
    On which points is the difference between a peripheral with device manager and an peripheral without device manager, referenced to the windows connection problem!? Thanks in advance!
