NRF5340 Nor Flash SPI/QSPI Fat FS
I am having some issues with spi flash and current.  Currently I have the NOR Flash, W25Q128JVPIQ, set up on spi 4 with a FATFS and USB MSD as per customer request.  This is working but when idle I am seeing an extra 580uA of current in this configuration which seems odd.  Included is my project config and device tree.  I cant really figure out what is wrong other then there is a flaw that is keeping the interface up or not letting the chip idle.  I have also tried the below QSPI config and while it gets the JDEC ID and the fs code reports a file system was created it can not mount the FS.  In an ideal case I would like to move or configuration to QSPI and have it reach an appropriate idle power level.  Currently we are using 1.7.1 sdk and I am using a fluke 87 multimeter for current measurement and have the nrf5340 idle current at 3.8uA and with the FS enabled it is 580uA.  In the old nrf sdk I used chan fs and this spi flash and had no power issues so this seems to be zephyr config related.  Any help would be appreciated.
CONFIG_SPI=y
# CONFIG_SPI_4=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_SPI_NOR_IDLE_IN_DPD=y
#FLASH Config ##############################################
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_FS_FATFS_LFN=y
CONFIG_SETTINGS_FS=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_LOG_LEVEL_ERR=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_DISK_DRIVER_FLASH=y
# CONFIG_FCB=y
# CONFIG_SETTINGS_FCB=y
CONFIG_DISK_FLASH_DEV_NAME="MX25L32"
CONFIG_DISK_FLASH_START=0x0
CONFIG_DISK_VOLUME_SIZE=0x1000000
CONFIG_DISK_FLASH_MAX_RW_SIZE=4096
CONFIG_DISK_FLASH_ERASE_ALIGNMENT=0x1000
CONFIG_DISK_ERASE_BLOCK_SIZE=0x1000
 &qspi {
// 	status = "okay";
// 	sck-pin = <17>;
// 	io-pins = <13>, <14>, <15>, <16>;
// 	csn-pins = <18>;
// 	mx25l32: mx25l3206E@0 {
// 		compatible = "nordic,qspi-nor";
// 		reg = <0>;
// 		/* MX25R64 supports only pp and pp4io */
// 		writeoc = "pp4io";
// 		/* MX25R64 supports all readoc options */
// 		readoc = "read4io";
// 		sck-frequency = <8000000>;
// 		label = "MX25L32";
// 		jedec-id = [ef 40 18];
// 		// sfdp-bfp = [
// 		// 	e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
// 		// 	ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
// 		// 	10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
// 		// 	30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
// 		size = <0x10000000>;
// 		has-dpd;
// 		t-enter-dpd = <10000>;
// 		t-exit-dpd = <35000>;
// 		rx-delay = <6>;
&spi4 {
	status = "okay";
	sck-pin = <17>;
	mosi-pin = <13>;
	miso-pin = <14>;
	cs-gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
		compatible = "jedec,spi-nor";
		label = "MX25L32";
		reg = <0>;
		spi-max-frequency = <32000000>;
		wp-gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
		hold-gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
		size = <0x8000000>;
		has-dpd;
//		has-be32k;
/delete-node/ &storage_partition;
&mx25l32 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		partition@0 {
			label = "storage";
			reg = <0x00000000 0x01000000>;
