QDEC on the nRF52840
using nRF5 SDK 17.1.0
Segger
I need some understanding of the QDEC.  if I connect a motor that has a A/B output at a 5KHZ rate.
what is the maximum rate at which the decoder can run?
what do i need to set the SAMPLEPER register to?  is 128uS preferred for faster decoder inputs?
I am looking to know position.  SO if I set the SAMPLEPER to a fast enough speed, what should i set the REPORTPER to?
is this expected to be larger for a longer sample period before events?
when i have the QDEC_EVENT_HANDLER() and do a event.data.report.acc
does this clear the accumulator?  or do i need to manually do this?
if manually do i set a task to RDCLRACC before i read the ACC in the event?
if so, how?
If I am not using the LED, do i just simply set ledpre =0 and there is no other setting needed?
thanks for you support
