Using a configuration file with mcuboot
SDK Environment: nRF Connect SDK v1.8.0
Target: Decawave DWM1001-DEV. This uses the nRF52832
I used \ncs\v1.8.0\bootloader\mcuboot\samples\zephyr\hello-world as a starting point and used ideas from here and here
I added
set(mcuboot_CONF_FILE
  prj.conf
  ${CMAKE_CURRENT_LIST_DIR}/mcuboot.conf
Just after cmake_minimum_required(VERSION 3.8)
And created the file mcuboot.conf
# MCUboot single slot with serial recovery
#CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
#CONFIG_BOOT_SIGNATURE_KEY_FILE="test-key.pem"
CONFIG_MCUBOOT_SERIAL=y
# Setup boot detect pin
CONFIG_BOOT_SERIAL_DETECT_PORT="GPIO_0"
CONFIG_BOOT_SERIAL_DETECT_PIN=2
CONFIG_BOOT_SERIAL_DETECT_PIN_VAL=0
# Enable serial recovery
CONFIG_BOOT_SERIAL_UART=y
CONFIG_UART_CONSOLE=n
CONFIG_CONSOLE=n
CONFIG_CONSOLE_HANDLER=n
# Enable single slot mode
CONFIG_SINGLE_APPLICATION_SLOT=y
When compiled I get the error:
CMake Error at C:/ncs/v1.8.0/nrf/modules/mcuboot/CMakeLists.txt:238 (file):
file STRINGS file "C:/ncs/v1.8.0/nrf/modules/mcuboot/prj.conf" cannot be
read.
prj.conf can be found at /ncs/v1.8.0/bootloader/mcuboot/boot/zephyr/prj.conf
If I instead add
Just after cmake_minimum_required(VERSION 3.8), the program compiles ok.
I would rather not have an absolute path to the file here, as this will catch me out when I update the ncs to a newer version.
I tried adding the following instead
  ${ZEPHYR_BASE}/bootloader/mcuboot/boot/zephyr/prj.conf
This does not work as ZEPHYR_BASE is not set yet. If I move this to after find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE}), the configuration in mcuboot.conf appears to have no effect.
Is there a better way to handle this?
I have attached the complete project:
6864.hello-world.zip
Built using
west build -b decawave_dwm1001_dev2 --pristine -d build2 /ncs/myapps/bootloader/hello-world -- -DBOARD_ROOT=/ncs/myapps/bootloader/hello-world
Programmed to the device using
west flash --runner nrfjprog --bin-file build/zephyr/app_update.bin -d build2
Firmware updates via the serial port using
mcumgr.exe --conntype=serial --connstring=COM8 image upload build2\zephyr\app_update.bin
  • Hi David,
    I found what worked for me the smoothest is putting a mcu_boot.conf into the child_image folder in the project root folder to have an overlay over the original proj.conf
    Doing that I don't need to define the path to the file.
  • Hi David,
    I removed the code set(mcuboot_CONF_FILE ... from "CMakeLists.txt"
    Created the folder "child_image" and moved "mcuboot.conf" into it.
    The project now does not build. It appears that "mcuboot.conf" in the folder "child_image" has replaced "\ncs\v1.8.0\bootloader\mcuboot\boot\zephyr\prj.conf" instead of adding to it.
    For a test, I added the contents of "\ncs\v1.8.0\bootloader\mcuboot\boot\zephyr\prj.conf" into the start of "mcuboot.conf". The problem now is that it is trying to find "test-key.pem" at 'C:/ncs/v1.8.0/bootloader/mcuboot/test-key.pem' instead of in the project directory. Changing CONFIG_BOOT_SIGNATURE_KEY_FILE in "mcuboot.conf" to an absolute path fixed that CONFIG_BOOT_SIGNATURE_KEY_FILE="/ncs/myapps/bootloader/key/test-key.pem". The project now builds.
    Is there a way using this method for "mcuboot.conf" in the folder "child_image" to be in addition to "\ncs\v1.8.0\bootloader\mcuboot\boot\zephyr\prj.conf" instead of replacing it?
  • Hi David,
    Could you tried again with my example here.
    Please edit mcuboot.conf to point to the absolute folder you copied the project to.
    I tested with nrf52dk_nrf52832 board and it worked both in VS Code and when compile from command line.
    peripheral_hr_SMP.zip
  • Thanks Hung Bui
    "peripheral_hr_SMP.zip" builds ok for me.
    I went back to see what the difference between your example and mine was. Previously when "mcuboot.conf" was in the folder "child_image", I had to add the contents of "\ncs\v1.8.0\bootloader\mcuboot\boot\zephyr\prj.conf" into the start of "mcuboot.conf" to get it to build. Now for some reason I don't have to. Simply moving "mcuboot.conf" into the folder "child_image" is now working. I have no idea what has changed apart from my computer being restarted.
    I have attached the updated version of hello-world
    hello-world2.zip
