nRF52805 OTA DFU no Bluetooth signal
I built a ble_app_buttonless_dfu_pca10040e_s112 project on the nRF52805. However, I cannot receive Bluetooth signal on nRF connect.
I have attached my generated hex file and used command in this post.
Please help me out. Thanks in advance!
1817.OTA.zip
    The attached hex files looks right to me, and indeed seem to work on my nRF52 DK (PCA10040).
    However, the command I used for programming was slighlty different from that in the attached text file: The last option should be "--reset" (with two dashes) and not "-reset" (with one dash). With the wrong version of the option, the board is not reset after programming. Manually resetting it, or correctly applying --reset, makes it work.
    I find it a bit strange that nrfjprog doesn't give any error response on the erroneous "-reset" option. If anything I would have expected it to treat r, e, s, e and t as individual short form options (which should both apply reset (-r) and trigger error on wrong use of the -s parameter.) The behavior looks like silently dropping wrongly formatted options, which I consider a bug. I have reported it internally for the nrfjprog team to look into and hopefully patch for a future nrfjprog release.
    Terje
    Did this solve the issue? If so I would appreciate if you accept the answer, so that others will find it and get help from it in the future.
    Terje
