I'm using the logger (LOG_INF, LOG)_DBG...etc) to print out debug messages. I'd like to have timestamp printed out. Right now it looks like this: D: xxxx or I: xxxxx
I found 3 CONFIGs that has the word timestamp in it. But seems none of them work. I'm not sure if I'm looking at the right direction.
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP
CONFIG_LOG_TIMESTAMP_64BIT
CONFIG_LOG_TRACE_SHORT_TIMESTAMP
So how to enable times tamping in logging?
Another logger question is, I keep getting warning like this.
"warning: LOG_BACKEND_RTT (defined at subsys/logging\Kconfig.backends:87) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: (!LOG_MINIMAL) (=n). See
docs.zephyrproject.org/.../CONFIG_LOG_BACKEND_RTT.html and/or look up
LOG_BACKEND_RTT in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too."
Looking up the document, there's no LOG_MINIMAL, only LOG_MODE_MINIAL. And whether I set it or not, it appears RTT is working because I can see output from RTT window so it must be working. I wonder what the warning message mean?
Thanks!
