Bluetooth and threading with Zephyr
Hey,
I'm trying to integrate BT + DFU functionality into my application, i'm following this example:
Add DFU support to your application - Software - nRF Connect SDK guides - Nordic DevZone (nordicsemi.com)
Everything is working fine, I can see device from nordic iOS app and even send strings. Everything fails, when i'm adding to program my own code.
I'm pretty sure that code itself isn't a problem. Please look at below examples in pseudocode:
COMBINATION THAT WORKS:
main() starts
enable BT and mcumgr OTA.
run my thread (only small inits)
my code executed in while loop, placed in main()
COMBINATION THAT DOES NOT WORK:
main() starts
run thread with my code (executed in thread's while loop)
So the problem occures only when i'm executing my code in thread's while loop. When i use while in main loop everything works.
Do you guys have any idea what is going on here? Maybe I should create separate thread only for bluetooth?
I'm using SDK 1.8.0 and nRF52832 dev board.
  • Ok, I partially solved my problem. Solution was running all BT and DFU init functions in main loop (or separate thread) and setting my code's thread priority down to 18 value .
    Running my code and BT inside one thread is apparently not a good idea.
    I'm glad you found a partial solution. However, I'm not exactly sure what could cause this issue. Could you share a simple sample that demonstrates the issue?
    Simon
  • I had to return to this problem, here is my current position:
    With CONFIG_ASSERT=n:
    main() starts
    enable BT and mcumgr OTA          - Bluetooth fully responsible
    delay 3s                                          - Bluetooth fully responsible
    run my thread (priority set to 18)    - Bluetooth not responsible at all
    With CONFIG_ASSERT=y:
    main() starts
    run my thread (priority set to 18)    - Bluetooth fully responsible
    My question is - why does enabling assertion globally solves this problem?
    I would rather not includ asserts in my code, as BT appliacation with asserts weights a lot,
    and i would better keep space for 2 program slots in my 512kB of flash.
    It's worth adding, that my thread is not influencing bluetooth or ota features, it's simple gpio, uart operations.
  • It may be helpful to look info my prj.conf. This one is without asserts (so it is not working)
    CONFIG_SIZE_OPTIMIZATIONS
    =y
    CONFIG_GPIO=y
    CONFIG_PWM=y
    CONFIG_ADC=y
    CONFIG_NRFX_TIMER0=y
    CONFIG_FLASH=y
    CONFIG_BT=y
    CONFIG_BT_SMP=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="Nordic_LBS"
    # Enable mcumgr.
    CONFIG_MCUMGR=y
    # Enable most core commands.
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    # Ensure an MCUboot-compatible binary is generated.
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    # Some command handlers require a large stack.
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Disable Bluetooth features not needed
    CONFIG_BT_DEBUG_NONE=y
    CONFIG_BT_ASSERT=n
    CONFIG_BT_DATA_LEN_UPDATE=n
    CONFIG_BT_PHY_UPDATE=n
    CONFIG_BT_GATT_CACHING=n
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=n
    CONFIG_BT_HCI_VS_EXT=n
    CONFIG_BT_CTLR_PRIVACY=n
    # Reduce Bluetooth buffers
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=1
    CONFIG_BT_BUF_EVT_RX_COUNT=2
    CONFIG_BT_L2CAP_TX_BUF_COUNT=2
    CONFIG_MULTITHREADING=y
  • Hmm.. It is hard to say why enabling asserts makes the issue go away. It would be much easier for me to investigate this if I get the sample, run it on an nRF52832 DK and reproduce it myself. Would it be possible to upload the sample here on DevZone (or a simplified sample that demonstrates the issue)?
    Simon
