Bluetooth and threading with Zephyr
Hey,
I'm trying to integrate BT + DFU functionality into my application, i'm following this example:
Add DFU support to your application - Software - nRF Connect SDK guides - Nordic DevZone (nordicsemi.com)
Everything is working fine, I can see device from nordic iOS app and even send strings. Everything fails, when i'm adding to program my own code.
I'm pretty sure that code itself isn't a problem. Please look at below examples in pseudocode:
COMBINATION THAT WORKS:
main() starts
enable BT and mcumgr OTA.
run my thread (only small inits)
my code executed in while loop, placed in main()
COMBINATION THAT DOES NOT WORK:
main() starts
run thread with my code (executed in thread's while loop)
So the problem occures only when i'm executing my code in thread's while loop. When i use while in main loop everything works.
Do you guys have any idea what is going on here? Maybe I should create separate thread only for bluetooth?
I'm using SDK 1.8.0 and nRF52832 dev board.
