Reconnect after sd_ble_gap_disconnect
Hi
I am using the nRF52832DK and the BLE_App_Blinky.
I have a stable BLE connection to a phone and then I try to close the connection inside the nRF with sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);.
It do a disconnect, but right after it reconnects again by firing BLE_GAP_EVT_PHY_UPDATE_REQUEST.
Why is this event generated? Do I have some settings that makes it reconnect or should I use another parameter instead of BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION?
Morten
  • Hi Morten,
    Could you let me know at which stage of the connection (for example if it's immediately right after connection) did you call sd_ble_gap_disconnect() ?
    Could you elaborate more on "but right after it reconnects again by firing BLE_GAP_EVT_PHY_UPDATE_REQUEST." ? You meant the nRF52 got connected to the phone (BLE_GAP_EVT_CONNECTED) and then you receive the event BLE_GAP_EVT_PHY_UPDATE_REQUEST?
    If your device (nRF52) start to advertises after it disconnected, there is a chance that the phone automatically re-connect to it.
    I would suggest to capture a sniffer trace so we get to understand what happens over the air.
  • I do a connect and then it triggers a BLE_GAP_EVT_PHY_UPDATE_REQUEST. Then the connection runs for 5 minutes before I call sd_ble_gap_disconnect(). This triggers the BLE_GAP_EVT_DISCONNECTED, so the connection is closed.
    A few milliseconds after that it reconnects which again triggers BLE_GAP_EVT_PHY_UPDATE_REQUEST.
    I would like to close down the connection entirely, so that the phone cannot reconnect to it after I disconnect.
    If I do a reset of the system, then it starts up with advertising disabled and the phone doesn't connect until I start advertising. I would think it is possible to shut it down without a reset?
  • Hi again Morten,
    If you don't want to advertise after you disconnect you can turn off config -> ble_adv_on_disconnect_disabled when you initialize advertising in advertising_init() (if you use ble_advertising module).
    If you don't use ble_advertising module, then there must be a call some where in the code for advertising start when the application handle BLE_GAP_EVT_DISCONNECTED event.
  • Thanks for your reply.
    I haven't had time to test it yet. But if I turn off config -> ble_adv_on_disconnect_disabled does that mean that it also will not reconnect if the phone gets out of reach and then back into reach?
    The thing I want to accomplish is that a phone connects to the nRF. When the nRF is finished sending data to the phone, the nRF disconnect the link to the phone.
  • Hi Morten,
    In that case you would need to handle the re-advertising on your own.
    What you need to do is to set a flag when the nRF52 actively disconnect the connection. In that case you don't re-advertise (start advertising after disconnected). If the flag is not set, then you can start advertise in the BLE_GAP_EVT_DISCONNECTED  event.
    To be able to handle the task manually you need to disable ble_adv_on_disconnect_disabled.
