Only i2c nodes accepted in /soc/i2c@40004000/.
Hi, Hope you can help.
With a nrf52840dk development kit arriving tomorrow. We tried to make a start with a nRF52840 dongle, which we eventually want to use.
Connected to a MACREFDES117# Maxim Integrated Heart-Rate and Pulse Oximetry Monitor Development kit.
SDA <29>, SCL <31> ,GND, VDD OUT.
Using: nRF Connect SDK, Zephyr, MS Code.
Following the Guide > Peripherals and RF Test > TWI/I2C implementation with nRFx TWIS Driver. 4 Aug 2021
https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/peripherals/posts/twi-ic2-implementation-with-nrfx-twis-driver
>> Slight snag here:  TWIM setup using Zephyr driver.   4. Add the following node properties to boards/ .overlay
Red squiggly under twis_device1:nRF52840@28            Problem: Only i2c nodes accepted in /soc/i2c@40004000/.
Note: Compiler would be happy with '
i2c-device:nRF52840@28' unfortunately the Guide says:  'i2C or TWI?  Though technically different constructs, TWI and I2C are often considered to be operationally synonymous. Nordic has adopted the TWI nomenclature, while Zephyr has adopted I2C. For this document, I2C will only be used to be consistent with referenced Zephyr software and documentation.'
Any advice welcome. Many thanks,  Andy
